I saw a MA10QS on Ebay for $50. Is it worth it or is there something else I should look at? The 8" in my KIA Sportage just isn't cutting it. Here are the specs on the MA10QS The amp I have (Kicker ZX350.2) puts out 350w @ 4ohm bridged. Subwoofer Size: 10" Subwoofer Design: Round / Circle Main Cone Color: Black Silver Voice Coil(s): Single (1 voice coil) Impedance (per voice coil): 4 ohms Peak Power Handling: 500 watts RMS Power Handling: 250 watts Woofer Composition: Paper Woofer Surround: Rubber Sensitivity: 88 dB Top Mount Depth: 5.6" Recommended Enclosure Type: Ported / Vented Sealed
i knew a kid with 4 MA 12's.. in the right enclosure just about any sub can sound good as long as you don't go past its limits.
x2... u can make any sub sound good.. but some will have more output then others.. like that ma 10 is rated at 250rms.. it will prolly not be super loud.. but u can make it sound good..
