looking to put in a sub, quick question...
Discussion in 'Car Subwoofers' started by johnpd, Jan 17, 2008.
  1. johnpd
    johnpd Full Member
    alright so its been a long while since ive been on here, but a few months ago i put in an amp(alpine mrp-f550) and some alpine 6x9's, but now im unhappy with my 6x9s bass. they were never what i thought they would be, as far as how they would sound with the bass, but i know they are only 6x9's and they arent supposed to be "loud".
    so i was wondering if i could put a sub in using the current amp i have, which is a four channel 90 watts rmps per channel. but i want to keep my front speakers "amped" using the first and second channel, and ill use the remaining channels to bridge a sub? and ill just have my rear speakers wired to my h.u.
    i have read that my amp would be putting out 250 watts rms at 4 ohms with 2 channels bridged. so that sounds good enough to use a sub....i think.
    let me know what you guys think? it would be great!
    thanks
  2. aznboi3644
    If you want tighter and louder bass from your 6x9s than you should invest in sound dampening material.
    I have good bass and midbass from my 6x8s...why?? because of this
    once I finish the doors the bass will be even better...also those are 60 dollar a pair of kenwoods...they sound fantastic now.
    if you want to amp all of your speakers I would wire all four speakers in the car to the front channels of the amp.
    Then bridge the rears to a sub
  3. johnpd
    johnpd Full Member
    yeah i think about damping my rear deck sometimes, cause it rattels and buzzes sooo much. and it would help a lot.
    maybe ill do both...damp my deck, wire all the speakers to the first two channels and bridge a sub in the last two channels.
    but it is possible to do a sub with my situation?
  4. aznboi3644
    yes....entirely possible
  5. cccullen
    You guys are lucky... They don't sell sound dampening like that here in the Philippines for a reasonable price. The do have insulation somewhat like that but it has that look but foam in between and its two sided so it doesn't stick on unless you glue it. Would that be ok?
  6. aznboi3644
    I used Peel and Seal from lowes...its window flashing. Asphalt based but it should last a few years...by that time my truck will be dead lol
    once it gets warm I'm getting eDead
  7. cccullen
    We dont' have lowes here nor do they have Peel and Seal here either. I haven't seen any Asphalt based here anywhere. I gotta look more into it though. Just that two sided stuff i told you about. i how much of the eDead would you need to do your explorer?
  8. aznboi3644
    Well I want to do from the c pillar back and the doors again...I'm going to buy about 60 square feet.
    Also I am going to use duct insulating foam to reduce road noise also
  9. cccullen
    the duct insulating foam will also help the sound, correct?
  10. cccullen
    the duct insulating foam will also help the sound, correct? do you just stick that stuff on as well?
  11. pedro quiroga
    oh yes it will!at work we didnt have enough room to mount our new press' air pumps in our pump room so our only option was to install them in a pump cabinet.roughly 4x12.it has insulating foam about 1-2 in thick and it works very well.they are installed right in between both presses.
    you cant hear them things at all.well with both presses running it really dont matter anyways.lol
    when i do my weekly maint on them i have to get in the cabinet.it's like a night and day diffrence.very quiet indeed
  12. cccullen
    so with all these other CHEAPER ways to insulate a car, why do people buy all that expensive stuff like dynomat?
  13. G3n3R@1
    G3n3R@1 Full Member
    cuz they just dont know! lol, well its just the fact that it is 'meant' for car audio
  14. pedro quiroga
    You Have To Think About Moisture With The Foam Stuff. It Will Have To Go Some Were Water Can Never Get To It.
    On The Other Hand Im Sure It Will Do Great On The Roof And Rear Side Panels Of A Car/suv.firewall Too
  15. aznboi3644
    people want brand name sh!t like always
    this is the DIY world...whatever works
  16. jonnyv713
    exactly azn! i was just lookin at caraudio.com forum and o my god! they have limitless money. and i am sure they didnt install a thing, well maaybe a few but not many! they just have way to much money on that site, i dont really like it, its not my kind of world!
