looking at a new system AGAIN haha.
Discussion in 'General Car Audio Discussions' started by psycho_maniac, Apr 17, 2010.
  1. psycho_maniac
    psycho_maniac Full Member
    so usually when i get a new system ill go bigger. so im looking at a SoloX. The ones with 5000 watts rms. i was wondering if it matters if i got 2 12's or 1 18. what would the sound difference be? the only problem i had when looking this up before is an amp to power one. what are your suggestions?
  2. fstrfvo
    fstrfvo Full Member
    Id go with the 2 twelves. more cone space means more bass. But they peak at 5000 watts x2 so you will need a monster amp. Kicker warhorse= 10000 watts, of course you will need like 4 batteries and a monster alternator to power it, not to mention deep pockets.
  3. pedro quiroga
    the 18 will have more cone area. i know a kid with 2 in his explorer on 8k. 4k per.
    either ones will get loud in the right enclosure. how much are you getting them for?
  4. MTX4Life
    MTX4Life Full Member
    Maybe I don't know how exactly to add up cone area, but if you have 2 twelves won't that give you 6 more inches of cone area than one 18?
  5. DatDude08
    DatDude08 Full Member
    No, since Solo X subs are square do length x width to calculate cone area.
    18x18= 324
    12x12=144(2)= 288
  6. fstrfvo
    fstrfvo Full Member
    So if you measure a round sub straight accross, A 12 inch sub would have 12 inches of cone space, but you measure a square sub VxH to get 144 inches. So square subs have DOUBLE the cone area???
  7. DatDude08
    No, for a round sub you use the same formula you use to find the area of a circle which is (pi*radius squared) so the area of a 12 inch round sub is 3.14*6^2 -> 3.14*36 = 113 sq. in. The radius of a circle is half the total diameter, so a 12" sub has an approximate radius of 6", really though no sub has an actual cone that is 12" but it works the same for all subs.
  8. fstrfvo
    fstrfvo Full Member
    So are you saying radius and cone area are the same. I understand that the radius is from the center to the edge, but isnt that only going one direction. i think you would multiply that by 2 since you are going from edge to edge.
  9. pedro quiroga
    ive done it like this. radius x pi, then x radius.
    so 6(radius) x 3.14(pi) =18.84 x 6 =113.04 cubic inches of cone area.
    but for square subs its L x W. thus 12 x 12 or 18 x18.
  10. psycho_maniac
    so i should go with the solox 18" ? too bad i cant find them for sale anywhere :(
    also please help me with an amp. i have no clue on what to get with something this huge.
    and what do i want for coils? dual 1, 2, or 4? what really is the difference between the types of dual coils i have? I was wondering maybe get 2 of these?
    http://www.onlinecarstereo.com/CarAudio/p_19320_Kicker_08ZX25001.aspx ?
  11. eviling
    eviling Full Member
    I have a buddy who uses some of these
    http://www.thedeepdiscount.com/p-23...ms-mono-block-car-amplifier-1-ch-sub-amp.aspx
    4000 rms, their lower end models are meh, but from what i understand, their high end models like this one are very good. not quite 5000 watts, but it's a very good price for 4000 watts, surley after the 1000$ on that 18" solox, you could use a break ;)
    he has like 7 of them, he's trying to sell some, if you'd like i could get ahold of him, think he was asking something like 400$ they're only slightly used, don't think he used any many of them, he was sponsored by MA audio. so he got massive discounts.
  12. pedro quiroga
  13. pedro quiroga
    sorry, i meant 2k per. he had 4 1k amps to his subs.
  14. eviling
    eviling Full Member
    those would be so nice if it woudln't take 4 solox's to get down to .5 ohms, and at that point you're 16k watts behind haha but if you had 16k watts coming from your system, you're rocking pretty hard..youd probobly burst an ear drum like that o_O
  15. psycho_maniac
    actually the solox's are like 800 bucks. and money is no option. i hate going cheap.
  16. eviling
    eviling Full Member
    well, if moneys not an issue, more power to ya, and if thats the case, kicker does make an amp that'll put those subs in their place. I really know of no other amp that claims those ratings, so, 10000 watts rms at 2 ohms, you'll be rocking hardcore :eek:
    http://www.sonicelectronix.com/item_11192_Kicker+Warhorse+WX10000.1.html
  17. cccullen
  18. psycho_maniac
    any reason why to look at different subs? i like the sundown amps you linked to. ive seen them used before around here once i think.
