lookin for help
Discussion in 'Car Subwoofers' started by jmenace_thakidd, Apr 1, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    im lookin to upgrade my system a little bit right now i have a Rockford P3 15 pushed by a phoenix gold R1501 in a 02 galant. It hits but lookin to get deeper bass because i listen to alot of chopped and screwed music right not im lookin at
    Sound Stream Tarantula T5 15
    Kicker L7 15
    Diamond Audio D9 15
    which do u think will provide deeper bass any help is appreciated
    im lookin to spend up to 300 for a sub
  2. aznboi3644
    doesn't matter what sub.
    ENCLOSURE ENCLOSURE ENCLOSURE.
    What box is your sub in???
    I had a JL 15W4 in a custom ported box with 300 watts...I could hit 138dbs
  3. jmenace_thakidd
    its in a ported enclosure right now not custom to the P3
    so should i just get a custom box made?
  4. aznboi3644
    Why not build you a custom box...we can even help out with the dimensions and cut lists
    prefab boxes suck balls.
    Is it in a prefab ported box from Best Buy??
  5. jmenace_thakidd
    naw i got it from this audio place called sound solution down here in gulfport
    well if a custom box is all i need them ill have to get my trunk dimensions so u guys can help me out then
  6. aznboi3644
    Aight...a new box will DEFINITELY sound a lot louder and better
  7. jmenace_thakidd
    kool u know of any good place to get 0 gauge wire
  8. aznboi3644
    Nearest welding supply store.
  9. jmenace_thakidd
    kool
    i have the winISD on my laptop but im still learning how to use it
    if anyone could help how many cubic feet should i have for a rockford p3 15
    frequency response 22-250 hz
    displacement .107 cu.ft.
    free air resonance 22 hz
    qts .61
    vas
    xMAX .528IN
    SPL 86 dB
  10. Ranger SVO
    I wanna see what AZN recommends, but I will get you started. For low and loud and a single 15, I typically like to get around 3.5 to 4 cu ft. The galant has a large trunk, so that large a box might not be a problem. Port it but......
    the only problem I have with that woofer is the qts of 0.61. Thats kind of limiting, I need to know what QES is. I also need VAS but not right now.
  11. jmenace_thakidd
    i cant find the QES im still lookin its not in the owners manual but
    the VAS is 4.98 cu.ft.
    ima keep lookin and go to the rockford forum and ask
  12. aznboi3644
    William...somehow I knew you were gonna say that lol
    The thing I hate about RF is that they don't list a lot of T/S Parameters...because they suck at it
    All I could find from the RF online manual is the QTS, FS, VAS, and Xmax
    But using those in WinISD...there isn't much of a difference in the response at all from a 3 cu ft tuned to 40 Hz to a 4.5 cu ft tuned to 40Hz.
    Only difference was that the 4.5 cu ft box peaked a little over 1 db higher than the 3 cu ft box and peaked about 4 hz lower.
    The F3's of the 3 cu ft and 4 cu ft boxes are only about 2 Hz apart
    I'd do 4 cu ft tuned to 40Hz with a 15"x4" slot vent approx. 18.75 inches long.
    Ranger...how does that sound???
  13. jmenace_thakidd
    thanks yall i appreciate all the help gotta get this box built ASAP
  14. aznboi3644
    Take your time and build it RIGHT. You will very much appreciate it in the end.
    It takes me about 10 hours to build a big box...but that is because I like to work slow and take my time and do everything right...predrill all holes...drawy out the boards on the bottom board and dry fit everything so it lines up right with minimal gaps and such. I've seen a box put together for a couple 15L7s done in about and hour...it came out horrible.
    My friend who thinks he can build boxes used no screws...did not take his time and draw out every screw hole and line the holes up 3/8" from the edges and only used screws...it was one of the crappiest boxes I've ever seen and sounded horrible. When I took it apart every single screw hole split the wood and about an 1/8 of all the screws didn't even go through into the other boards...it was bad
    My first box was a simple 14 inch cube for one 12 inch sub...took me about 3-4 hours. Took my time and drew out every screw hole with equal spacing...3/8" from the edge. Drilled and countersunk. Didn't use glue but came out very good in the end
  15. jmenace_thakidd
    kool i will definately take my time then gotta get it right
    this will be my first time building a box im excited lol
  16. ibanezFreak87
    ibanezFreak87 Full Member
    um buddy. i hope it hit better than that. i had two 12inch infinity kappas ran by an alpine 1005m and they hit 137.4 dbs IN A SEALED box! lol
  17. ibanezFreak87
    and use a damn staple gun when putting a box together. its the easiest thing to use.
  18. jmenace_thakidd
    hey Azn are the 13kv2 a SQ or SPL sub my brother is lookin for some subs and i seen u recomended elemental designs
  19. aznboi3644
    Ibanez that was with 300 watts rms...Then I got a new amp and had that baby on 700 watts rms and was over 140dbs without the sub even breaking a sweat...yeah and it was rated at 200 watts rms!!!!
    how are dem apples??
  20. aznboi3644
    Elemental Designs is mainl concentrated on sound quality...ALL of their drivers sound excellent and are great for their price. These are one of few of the manufactures that makes their subs in the USA. They build them in house in Iowa.
    The subs are sq subs but can still get plenty loud.
    A 13Kv.2/3 with 400 watts is a perfect combo. These subs are underrated...there are people out there putting 300 watts to some ED 6.5 inch subs
