locs or line driver
Discussion in 'General Car Audio Discussions' started by fstrfvo, Oct 4, 2009.
  1. fstrfvo
    fstrfvo Full Member
    Im going to hook up my factory head unit to my amps. I have a PG tld 66 line driver, is there a way to hook the factory HU to that or do I still need to use LOCs
    those dont have speaker level in's do they? if not then you'll need an LOC.
  3. fstrfvo
    fstrfvo Full Member
    are there any locs that will provide 8 volts of clean signal to the amps? I dont thhink there is. So just install the locs then connect them to the line driver?
  4. pedro quiroga
    yeah that sounds about right. um as far as 8v out. isnt the PG one 8v?
  5. fstrfvo
    fstrfvo Full Member
    So should I just wire in the LOCs then connect them to the line driver, yes the PG will put out 8 volts, maybe more but its been a while since I looked at the specs.
  6. pedro quiroga
    sounds right. since you have the loc and a line driver. mess around with the gain on the loc before tucking it away in the dash, or where ever its going.
