alright fellas i jus bought a JL w612 300 watts rms and a kicker ZX300.1 for 140 dollars and for now i jus wanna run it 2 my stock stereo any suggtions on wat L O C 2 buy i was looking 4 some on e bay found some good deals wat do u guys suggest i do want a clean sound so any that works better would help thankx line output converter, Car Electronics, Parts Accessories items on eBay.com
AudioControl LC6i (GRAY LC6) - (COLOR: SALMON GRAY) Six Input and Output Channels • AutoMode Inputs • Signal Sensing Inputs • Line Output Converter - , Factory Stereo (OEM) Integration, Factory Sound Processors - Sonic Electronix
well i jus wanna hook up the mono nothing else so wat do i look 4 do some give u differtn watts or wat and wat do u adjust them 4 and do i need 1 with a remote wire wat about these Stinger High Power Fixed Line Output Converter SLOCII - eBay (item 170208615282 end time Apr-13-08 18:36:19 PDT) Stinger High Power Fixed Line Output Converter SLOC - eBay (item 310039090071 end time Apr-13-08 18:36:22 PDT) NEW PREMIUM LINE OUTPUT CONVERTER W REMOTE TURN ON NRRM - eBay (item 360040040968 end time Apr-11-08 19:00:00 PDT) PAC SNI-35 SNI35 LINE OUTPUT CONVERTERS *BRANDNEW* - eBay (item 120244123278 end time Apr-14-08 13:57:28 PDT)
go with PAC but not that one.i dont see that it has a remote out. also look for one that give you the highest voltage out to your amp.
eBay Motors: pac oem-2 4 channel line out converter (item 170208892420 end time Apr-14-08 18:32:37 PDT)
were will i b able 2 mount it at and how far will it b from the amp in the trunk and wat do i conect it 2
for the 2ch one it can go in the trunk.it doesnt matter how close or far to the amp it goes. it should come with instructions to show you how to install it. if it has a remote out.it will more than likely need power going to it also. you will tap into your rear speakers.
well alright i found 2 soundgate LOCs there for a good price 2 so i dont know if the have remote trun on leads but i think these would problay give me better wattage than the tunk pac wat do u guys think thankx Soundgate Loc4.2 2-Channel Line Output Converter - LOC4.2 - Buy.com Soundgate Locx 2-Channel Line-Output Converter - LOCX - Buy.com
well i already have apioneer permier jus dont want 2 put in there i save it im probaly gonna get a blazer and through my kickers in there as well but there is no other way i can run a turn on lead some other way by the way wats the differnce between the LOCs that i posted up and cavalier has 4 speaker wires for each channel in the rear but not in the front
