Kole Audio KX1-3000d
Discussion in 'Car Stereo Amplifiers' started by jmenace_thakidd, Jul 21, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    here are the specs i was thinking about getting one of those new
    Ascendant Audio Havoc 18s i think the combo would work ok any
    comments
    Full Mosfet Power Supply
    PWM Circuitry
    Full Selectable Crossover Hi/Full/Low
    Three Way Protection Circuit
    2 Ohm Stable Stereo
    Tri-Mode Capable
    Variable Low Pass 30Hz-500Hz
    Variable Hi Pass 50Hz-500Hz
    Variable 24 dB Bass Boost
    Variable Subsonic Filter 60Hz-200Hz
    Frequency Response: 10Hz to 30KHz
    S/N Ratio: 98 dB
    THD: 0.02%
    System Distress Indicator
    4 Guage Power/Ground Connection
    End Caps for Clean Installation
    Gold Plated RCA Connectors
    Line Output
    Top Vent For Accelerated cooling
    Power Handling :
    900 W RMS x 1 CH @ 4-ohms
    1300 W RMS x 1 CH @ 2-ohms
    1700 W RMS x 1 CH @ 1-ohms
    Max Power : 3000 Watts
    Remote Bass Boost Included
    Dimensions (WxHxD) : 13.5" x 2.3" x 11.7"
  2. jmenace_thakidd
    has anyone every delt with Kole audio?
  3. aznboi3644
  4. pedro quiroga
    azn.the kole 3000d and the power akoustic share the same board.
    Power Acoustik A3000dB
    so unless i'm wrong.it's the same thing.
    BTW kidd i know a guy with 6 3000d's.they rock.he hasnt had a single prob with them yet.they do put out some juice.
  5. aznboi3644
    Same boards....but the quality of the components are prolly different.
    Like the Soundstream XXX-6500D has the same board as the Lanzar Opti4000D
  6. pedro quiroga
    about that idont know.maybe.?you may be right.
    when i first met the guy with the 6 3000d's.he mentioned somthing about them having the same board as a more expencive amp.so he got the PA's instead of.....i wanna say a soundstream amp that was 100 bucks more.
    i would think same board same amp.just a diff case.
    i'm really not sure.i wonder if anyone here will know?
  7. jmenace_thakidd
    yea its not that expensive i think they got it on millionbuy for like 210 i might just try it out i know im gonna get that Ascendant Audio Havoc 18 though says they rated it low at 1250 rms
  8. pedro quiroga
    sweet.show us some pics when its up and running.
  9. jmenace_thakidd
    i will definately post up pics of the install when i get it all here i still have a week or two before they release the Havoc series u know they are just now putting them back on the market and i cant wait a friend of mine has 2 of the old arsenal series subs and they are bad ass
  10. Jeffc879
    Jeffc879 Full Member
    yo i would highly recommend the power acoustik db series. they are class d, but not really clean. they draw a lot of power too. i had a db2400 and it was spec'd at 1800rms at 1 ohm. i had it tested it was like 1639 rms at 1 ohm or something. but it still pushed my sub hard. just not a clean amp. highly recommend for a pounding system on a budget
