Kicker ZX1000.1
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, May 9, 2011.
    $369.00
    1000W RMS Class D Monoblock ZX Series Subwoofer Amplifier (11ZX1000.1)
    Power Output:
    • 500W RMS x 1-Channel @ 4 Ohms
    • 1000W RMS x 1-Channel @ 2 Ohms
    • High-Efficiency Class-D Design in most monoblock amps
    • KickEQ™ Boost with variable gain up to 18dB centered at 40Hz
    • Active 50-200Hz variable 12dB/octave XOVER with selectable HiPass, LoPass, or AllPass capability on full-range channels
    • Active 50-200Hz variable 24dB/octave LoPass XOVER on mono channels
    • Automatic turn-on options include: 12 volt remote turn-on, DC offset, and audio signal sensing
    • Differential Hi- and Lo-Level Inputs for integration in any system
    • Advanced protection circuitry: low/high voltage, over-current, and thermal protection with indication on end panel
    • All feature FIT™ Fail-Safe Integration Technology with advanced input design
    • FIT accepts output from virtually any source unit – factory or aftermarket – low signal-level to high speaker-level
    • FIT's isolated inputs reject electrical interference for noise-free operation
    • FIT's three turn-on modes interface with virtually any vehicle's electrical system
    • Bass Remote Included
    General Specifications:
    • Frequency Response: 25-200Hz, +0/-1dB
    • Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
    • Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
    • Active Crossover: 24dB/octave, variable 50Hz-200Hz, low pass only
    • 24dB/octave high-pass subsonic filter fixed @ 25Hz
    • KICKEQ™ Boost: Variable to +18dB, centered @ 40Hz
    • Height: 2-1/8"
    • Width: 9-5/8"
    • Depth: 16-3/4"
