Kicker Or Power Accoustik Amplifier
Discussion in 'Car Stereo Amplifiers' started by E-dubb, May 22, 2006.
  1. E-dubb
    E-dubb Full Member
    Hi witch amp should i get to power my....
    TWO S10L7 2ohm 600 rms
    Kicker 750.1 class D
    OR
    Power Accoustik 900.1 class D
    OR
    ROCKFORD FOSGATE TYPE RF X6C 1100W MONO AMPLIFIER D
  2. ramos
    ramos Full Member
    Allthough I don't think either is enough power. I would choose the Kicker anyday over pa :)
  3. aznboi3644
    if you put em in a ported box the 750.1 should do em pretty well.
  4. Hautewheeler
    Hautewheeler Full Member
    yeah.. um okay!
  5. Hautewheeler
    I agree with ya fella's.. pa stuff used to be nice, but not anymore. And don't get me started on the fosgate's fall from grace. Use the kicker unless you want to keep buying pa's and fire extinguishers. and a ported enclosure will yield max movement for the power.
  6. aznboi3644
    yes hautewheeler we heard you the first time lol.....jk
  7. Hautewheeler
    how the heck did I do that?:lol:
  8. basshead4life56
    basshead4life56 Full Member
    i got a mmats amp for sale that will kick the **** outa all those amps its a d 3000 1/2 ohm stable 2500 watts true power for 900$ great compition amp or evrey day use its only been used 10 times
    thanx joel seventhgest@aol.com
  9. aznboi3644
    You dont need that amp. Plus its 900 bucks. That amp would be way overkill for your L7 10's
  10. fstrfvo
    fstrfvo Full Member
    In my wifes car im using a mtx 942 amp mono in 4 ohms to one L7 12 inch in a sealed box. This thing has hit over 154db with one sub. For an everyday system this thing will rattle everything in the car, not to mention your fillings. Save your money and just get the one twelve if you have not bought the 2 tens yet. You can still find the 942 around for about 400 to 600 dollars.
  11. aznboi3644
    fstrfvo, what kind of box do you have that l7 in?
  12. ramos
    ramos Full Member
    over 154db in a sealed enclosure ? Should enter meca or dbdrag then . That's over the numbers tommy k is putting up with a single 10" in a pick up. :)
  13. aznboi3644
    did it hit 154db on a term lab?
  14. ramos
    ramos Full Member
    Also, where was the mic ? :)
  15. aznboi3644
    Sorry I'm just skeptical of a 12L7 hitting that in a SEALED enclosure...154 db is pretty high...Please post specs of box, location mic, and type of db meter.
  16. ramos
    ramos Full Member
    Me too , just being nice about it. Don't think it's possible with that sub in a sealed enclosure . :)
