Kick Panels
Discussion in 'General Car Audio Discussions' started by jnc2000, Apr 21, 2004.
  1. jnc2000
    jnc2000 Full Member
  2. Steven Kephart
    Steven Kephart Full Member
    The Koda's are designed for off axis mounting, and give a flat response when mounted that way. Putting them in kick pannels will make them brighter. Also, the mids are going to be in a smaller enclosure, so you will lose some midbass. I think it would make it worse rather than better.
    I would recomend instead using that money to pick up a processor with delay capabilities. That will give you the couple miliseconds of delay you would get from the kick pannels, but without effecting the frequency response.
    Steven Kephart
    Adire Audio
  3. jnc2000
    jnc2000 Full Member
    what should i use for kick panels? are you saying use the stock mounting positions?
  4. KhaoticLE
    KhaoticLE Full Member
    if you do end up getting a Qlogic kick.....you should fabricate it with couple layers of fiberglass to make it stronger!!!!
    b/c those Qlogic kicks are made of thin plastic and it can sound worse than your factory location...
  5. Steven Kephart
    That is where they were designed to be mounted. I think you will get the best performance that way.
    Steven Kephart
    Adire Audio
