$199.00 600W RMS 4-Channel Digital Car Amplifier General Features RATED OUTPUT POWER (14.4V): 100W RMS x 4 @ 4 Ohms (20Hz-20kHz @ 0.05%THD) 150W RMS x 4 @ 2 Ohms (1kHz @ 0.5% THD) 300W RMS x 2 @ 2 Ohms (Bridged) (1kHz @ 0.5% THD) RMS POWER OUTPUT (CEA-2006) 100W RMS x 4 (RMS @ 4 Ohms, 1% THD+N) 85dBa Signal-To-Noise Ratio BUILT-IN CROSSOVER CONTROL: Variable High-Pass Filter: 50Hz-200Hz (-12dB/oct) Variable Low-Pass Filter: 50Hz-200Hz (-12dB/oct) TERMINALS: Battery: Hex Type (4 AWG) Ground: Hex Type (4 AWG) Speaker: Hex Type (8 AWG) Operating Voltage: 14.4V Current Consumption: 64A S/N Ratio: 105dB Frequency Response: 5Hz-50kHz Input Sensitivity: 0.2V ~ 5.0V Installation Size: Width: 14-15/16"(380mm) Height: 2-5/8"(66mm) Depth: 11-1/4"(286mm) Weight: 10.8 lbs. (4.9Kg) More...
