Kenwood Excelon X600F \RB
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Jan 5, 2011.
    $199.00
    600W RMS 4-Channel Digital Car Amplifier
    • RATED OUTPUT POWER (14.4V):
      • 100W RMS x 4 @ 4 Ohms
      • (20Hz-20kHz @ 0.05%THD)
      • 150W RMS x 4 @ 2 Ohms
      • (1kHz @ 0.5% THD)
      • 300W RMS x 2 @ 2 Ohms (Bridged)
      • (1kHz @ 0.5% THD)
    • RMS POWER OUTPUT (CEA-2006)
      • 100W RMS x 4
      • (RMS @ 4 Ohms, 1% THD+N)
      • 85dBa Signal-To-Noise Ratio
    • BUILT-IN CROSSOVER CONTROL:
      • Variable High-Pass Filter: 50Hz-200Hz (-12dB/oct)
      • Variable Low-Pass Filter: 50Hz-200Hz (-12dB/oct)
    • TERMINALS:
      • Battery: Hex Type (4 AWG)
      • Ground: Hex Type (4 AWG)
      • Speaker: Hex Type (8 AWG)
    • Operating Voltage: 14.4V
    • Current Consumption: 64A
    • S/N Ratio: 105dB
    • Frequency Response: 5Hz-50kHz
    • Input Sensitivity: 0.2V ~ 5.0V
    • Installation Size:
      • Width: 14-15/16"(380mm)
      • Height: 2-5/8"(66mm)
      • Depth: 11-1/4"(286mm)
      • Weight: 10.8 lbs. (4.9Kg)
