JL Audio 12W1v2-4
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Jul 31, 2013.
    $105.00
    12" 150W 4-Ohm Subwoofer
    • 150 Watts Continuous Power Handling (Pt)
    • Single 4 ohm Nominal Impedance (Znom)
    • 0.375 inches / 9.5 mm One-Way, Linear Excursion (Xmax)*
    • 12.0 inches / 300 mm Nominal Diameter
    • 12.5 inches / 317.5 mm Overall Diameter
    • 5.09 inches / 130 mm Mounting Depth
    • 8.61 lbs. / 3.90 Kg Net Weight
    • 0.035 cu. ft. net / 0.99 liters Driver Displacement
    • 1.25 cu. ft. net / 35.4 liters Rec. Sealed Enclosure
    • 1.75 cu. ft. n12W1v2
