JL Audio 10W1v2-4
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Jun 26, 2013.
    $116.00
    10" 150W 4-Ohm Subwoofer
    • 10" W1 version 2 4-ohm subwoofer
    • Continuous Power Handling (Pt): 150 Watts RMS
    • Nominal Impedance (Znom): Single 4 ohm
    • One-Way, Linear Excursion (Xmax)*: 0.375 inches / 9.5 mm
    • Nominal Diameter: 10.0 inches / 250 mm
    • Overall Diameter: 10.5 inches / 267 mm
    • Mounting Depth: 4.34 inches / 110 mm
    • Net Weight: 7.81 lbs. / 3.54 Kg
    • Driver Displacement: 0.025 cu. ft. net / 0.71 liters
    • Rec. Sealed Enclosure: 0.625 cu. ft. net / 17.7 liters
    • Rec. Ported Enclosure: 1.00 cu. ft. net / 28.3 liters, tune to 31 Hz
