/ Register
Jeep Wrangler Sub Box
Discussion in 'Car Subwoofers' started by Wrangler Audio, Apr 12, 2007.
  1. Wrangler Audio
    Wrangler Audio Full Member
    will be buying my first wrangler in the next month or so and realized not much space in the back for a sub box. any one with any ideas or previous experience. also for around $250 what would be recommended for a sub
  2. cccullen
    You can get a lot for $250. First we all have to know the following:
    what size sub/s are you looking for?
    How many sub/s do you wana put in your wrangler?
    What kind of amp will be powering the sub/s?
    Are you going for SQ or SPL?
    Are you going to make your enclosure?
    Everyone will tell you around here that it's not the sub that's really important , its the enclosure which is very true. I'm asking all these questions to give all the experts here on the forums enough info to answer your question...
    for the mean time, i looked up some custom made enclosures that you can take a look at. here are the links:
    http://www.just4effect.com/10SUBBOX.htm
    and
    http://www.offroadtoystore.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=33-5200&Category_Code=33Eng
  3. Wrangler Audio
    1x 12 inch
    an amp around $300-400
    a combination of both SQ and SPL
  4. Wrangler Audio
    any suggestions for an amp to run that and some typr R splits priced at $300 400
  5. jmenace_thakidd
    jmenace_thakidd Full Member
  6. cccullen
    are you planning to use the dual 2ohm or dual 4ohm type r's and what's the rms on the 12 you want? Anyhow the usual RMS on a type r is roughly 500 watts. For an amp to run that, you have a lot choices for your budget.
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3804&CFID=4168448&CFTOKEN=d8a09747f0a05c8c-EB81D881-1422-7C6E-50FDDC56A1C87B39
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=235&CFID=4168448&CFTOKEN=d8a09747f0a05c8c-EB81D881-1422-7C6E-50FDDC56A1C87B39
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3788&CFID=4168448&CFTOKEN=d8a09747f0a05c8c-EB81D881-1422-7C6E-50FDDC56A1C87B39
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12982
    there are a lot more to choose from. It's getting late for me, i'm sure that once viking, dave, ranger and azn see your post they will have a lot more to offer.
  7. cccullen
    LoL. I just realized your budget is 300-400. all that set in my mind was 300.
  8. pedro quiroga
    have you looked into a jl audio stealth box.it would replace your center console.also maybe a marine amp and comps would be in order.
    unless its a hardtop.also.what year jeep.?you never said.
  9. Wrangler Audio
    jeep is hard top 98
    and wats the difference between the 2 type r subs 2ohm and the 4ohm
  10. Wrangler Audio
    also just realised that i was talking aus dollars
  11. pedro quiroga
    what currency will you be useing?
  12. Hautewheeler
    Hautewheeler Full Member
    check out the kicker solo 8 or 10 in a bandpass or large ported enclosure.
    you can go larger because of just using one sub, and save money on the amp too.. those little square speakers will really fill up that jeep with sound.
  13. cccullen
    aus dollars (Australian dollars) he's from down under i guess
