Is the pioneer PRS-D5000SPL enough
Discussion in 'Car Stereo Amplifiers' started by red hot pepper, May 18, 2007.
  1. red hot pepper
    red hot pepper Full Member
    hi can someone here help me please, i'm new to the audio world but would like to hit the ground running . Dont understand how to use this post either but still trying anyway I have 2 pioneer subs 3000w max each and 1000w rms. What i want to know is the Pioneer prs-d5000spl amp which max is 3000w and rms is 750w is enough to push these two subs or do i have to buy 2 amps.
  2. aznboi3644
    I wouldn't buy that amp...What impedance are your subs??? How much money do you wanna spend??
    Doesn't matter what subs you have....if you don't have a good enclosure than you won't be that loud or sound good
  3. red hot pepper
    Hi, thanks for replying
    I would like to spend under $500US. The impedance of the subs are 2 ohm or 8 ohm (4 ohm dvc)
    you said you wouldnt buy this amp why?
  4. aznboi3644
    This amp is only stable down to 2 ohms.
    With your two subs you have a final load (using both coils) of either 1, 4, or 16 ohms.
    At 4 ohms you'd be giving each sub about 300 clean watts
  5. red hot pepper
    The pioneer amp has 1500w @ 2ohm thats more than the amp you recomended which only has 1475 @ 1ohm and 1000w @ 2ohm:confused: . Why this amp over the pioneer ?
    http://www.avcarexpo.com/22.html
  6. aznboi3644
    yeah sure that amp will work for ONE sub.
    That other amp is 1 ohm stable. If you want to use the Pioneer amp you will have to buy two of them. Reread post #4
  7. red hot pepper
    ok, but tell me, is there any sound change when you wire down the speaker from 4ohm to 1ohm ?
  8. aznboi3644
    sound wise...there is no difference between any impedences with the same woofers
