/ Register
is my mojo clipping???
Discussion in 'Car Subwoofers' started by crazywhiteboy91, Dec 14, 2009.
  1. crazywhiteboy91
    crazywhiteboy91 Full Member
    ok i ended up getting my mojo. got a MA audio 1000 watt comp. series amp powering it. its 1000 rms at 2 ohm so i wired it up to one voice coil and then i proceded to bump. on heavy bass songs it sounds like the sub is bottoming out. im thinking theres no way a 1000 watt amp is gonna bottom out a mojo. is it clipping do you think?
  2. Kvo_8
    Kvo_8 Full Member
    no way we can really tell if you're clipping..but if it sounds like the sub is bottoming out, then turn down the volume man, also remember you are running one coil. when a sub is rated 1000rms, that means each coil is rated at 500 rms a piece.
  3. crazywhiteboy91
    is the mojo really rated at 1000 rms? i was told they take 2500 rms daily
  4. Kvo_8
    Kvo_8 Full Member
    yup, i looked it up on sonicelectronix
  5. pedro quiroga
    wire both coils. or you could damage the sub
  6. crazywhiteboy91
    amp can only take a 2 ohm load. ive always been told there are dual voice coils so you can wire it to different loads depending on your amp. ive heard it dont matter if you run one voicecoil or not. idk. i guess its either damage the sub or the amp huh?
  7. crazywhiteboy91
    hmmm i couldent find a mojo on sonic elctronix. can ya send me a link?
  8. jonnyv713
  9. pedro quiroga
    yes using both coils wire either series or parallel. not just one coil.
    if its the D2 then a 4 ohm load is your only choice.
  10. crazywhiteboy91
    that must be the older model of mojo. mine looks alot different
  11. jonnyv713
    are you sure you have a mojo then? that is the only mojo i have ever seen.
  12. crazywhiteboy91
    yea 100 percent sure. even says mojo under my M logo
  13. crazywhiteboy91
