Ipod/amp
Discussion in 'Car Stereo Amplifiers' started by 5rob5, May 22, 2010.
  1. 5rob5
    5rob5 New Member
    I need some help . I have a 55 chevy and don't really have a place for a stereo, so my thought is to put an amp in the trunk and just use an ipod. I'm not sure if I can do this and if I can what would be a good amp for this? Basically what I'm asking is what would I need for this setup( amp, cord for ipod, etc)? I'm only running a pair of 6x9 three ways in the rear. Any help would be appreciated.
    Thanks, Rob.
  2. fstrfvo
    fstrfvo Full Member
    If there is no radio what are you using to power the 6x9's
  3. 5rob5
    5rob5 New Member
    I had a deck inside the glove box but I really don't like it there. I want something that I can throw under the seat when I'm not using it. Maybe even a cd player in the trunk that I can control with a remote. The problem with a hotrod is modern stereo equipment looks out of place in them. Any help would be appreciated.
  4. Ranger SVO
    Interesting Idea, I wonder if it will work. It should. So you will need a small amp to power your speakers. I figure any amp should work.
    Next you will need an iPod to RCA cable, that should be no problem.
    http://www.amazon.com/Cables-4-Feet-Stereo-Connector-Cable/dp/B000JG3WBY/ref=dp_cp_ob_e_title_0
    The only thing is you won't be able to charge you iPod.
    I'm sure there are other options. I wonder?? This might work
    A better cable option might be the PAC Audio part
    http://www.pac-audio.com/productDetails.aspx?ProductId=632&CategoryID=45
