I wanted to install one of these in my car and I don't know how I would go about doing so..so I figured I'd take the question here and see if you guys could help me out. I've attached a few pics so you guys can get an idea of what my battery looks like and such.
the battery terminal I wanted to install can be found here: http://www.knukonceptz.com/productDetail.cfm?prodID=KBT-30P
does your factory power wires have any slack in them? if not then maybe a ring terminal can be squeezed under the factory bolt on the positive terminal. thats why i went with a batt with 4 terminals.
im not sure if it has any slack in it, but i'll check. i wish i would've gotten a battery with 4 terminals now i just didnt think of it when i got the battery lol
well then maybe a ring terminal to the OEM batt is what you can do for now till you figure out another way. maybe redoing the OEM positives and neg's with good 4 gauge are in order. starter to batt,alt to batt,and what ever the other little wire goes to. the grounds are easy too. shouldnt use more than 10 more ft of each. hope that helps. maybe thicker wire on the starter tho.
