Install questions
Discussion in 'Car Alarm, Remote Start and other Accessories.' started by newbie99, Mar 20, 2006.
  1. newbie99
    newbie99 Full Member
    ive been searching around to find someone who can install my alarm/starter but because its not therer product no one can do it and i had a few people tell me that they would gige it a try for 450-500 buks now i think i could do it but the diagram dosent tell me what wires go where can anyone help me out this is a page guard 8500s 2way system and a 2003 sunfire
  2. eclipser6
    eclipser6 Full Member
    try the12volt.com they should have a diagram for your car as far as wires go
  3. newbie99
    i went there ive got the diagrams now but im trying to find out where the rest of my wires go from the alarm and also im trying to figgur out how to hook up the bypass module this is how far i am now
    12 VOLT CONSTANT RED (+) IGNITON SWITCH HARNESS =
    (pin 1) on 6 pin starter harness
    STARTER YELLOW (+) IGNITION SWITCH HARNESS =
    (pin 2) on 6 pin starter harness
    STARTER 2 N/A
    IGNITION 1 PINK (+) IGNITION SWITCH HARNESS =
    (pin 3) on 6 pin starter harness green
    IGNITION 2 N/A
    IGNITION 3 N/A
    ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS = (pin 4) on 6 pin starter harness blue
    ACCESSORY/HEATER BLOWER 2 N/A
    KEYSENSE N/A
    PARKING LIGHTS ( - ) N/A
    PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL =
    POWER LOCK LIGHT BLUE (TYPE C) See NOTE *1 IN EITHER KICK PANEL
    POWER UNLOCK WHITE (TYPE C) See NOTE *1 IN EITHER KICK PANEL
    LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS
    DOOR TRIGGER See NOTE *2 IN DRIVERS KICK PANEL and PASSENGER KICK
    PANEL 14301_SUNFIRE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
    DOMELIGHT SUPERVISION GREEN/BLACK (-) IN DRIVERS KICK PANEL =
    (pin 7)on 14 pin main harness grey wire
    TRUNK RELEASE BLACK/WHITE (+) @ BCM, See NOTE *3
    SLIDING POWER DOOR N/A
    HORN BLACK (-) @ STEERING COLUMN HARNESS
    TACH PURPLE/WHITE IN MAIN ENGINE HARNESS
    WAIT TO START LIGHT N/A
    BRAKE WHITE (+) @ SWITCH ABOVE BRAKE PEDAL =
    (pin 8)on 14 pin main harness red & white wire
    FACTORY ALARM DISARM N/A
    ANTI-THEFT YELLOW (+) and BLACK (-) and WHITE (Not Used) GM's PASSLOCK 2 System, wires are under the Steering Column cover, at the Bottom of the Ignition Switch Tumbler in a BLACK or DARK GRAY Plug
    thats what i got so far and this is what im missing
    Pin 5 orange on 14pin main wire harness armed output (-)500mA. The qrange wire provides a ground output while armed to activate a relay for starter defeat and anti-grind protection.
    pin 12 yellow: generator input (+) connect to the wire that shows more then (+)6v when engin is running this wire detects the status of the engine
    pin 3 white left signal light
    pin 4 white right signal light
    and also i need to know what connects to the clutch switch
  4. newbie99
    is anyone there to give me a hand
  5. newbie99
    dose this look right ta any one out there who knows a little bit about installin a alarm
  6. newbie99
    anyone here
  7. newbie99
    ive got a better diagram if youd like to see it its everything i got hooked up and the things im missing but i dont know how to upload it id go to the 12volt website but they didnt want to help me this is my verry firs install and id like it to go smooth
  8. clipser-gs-t
    clipser-gs-t Full Member
    Dude this is nothing to mess with yourself. There is so much that go wrong. I would highly recommend having a pro do it. At our local shop sometimes they even need help from the computer.
  9. eclipser6
    yea i did remote start and alarms at a shopped i worked at and if you havent had training or experience i wouldnt mess with it i've seen guys fry their entire car b/c of a miss placed wire.
  10. newbie99
    ive already started to do it just because all the install shops i wen to dont want to go near it because its not there product they want to charge me 500buks to do it i dont have that kinda money this is what ive got so far
    6 Pin Starter Harness
    Pin 1: RED WIRE Main power input (+12 volt).
    Connected Pin 1: 12 volt constant red (+) Ignition Harness
    Pin 2: YELLOW WIRE Starter output (+12volt).
    Connected to Yellow Starter (+) Ignition Harness
    Pin 3: GREEN WIRE Ignition Output (+12volt).
    Connected to Ignition 1 Pink (+) Ignition Harness.
    Pin 4: BLUE WIRE Accessory Output (+12volt)
    Connected to Accessory/Heater Blower 1 Orange (+ ) Ignition Harness.
    Pin 5: BLACK WIRE Ground Input (-)
    Connected just right of the steering column on the chassis.
    Pin 6: WHITE WIRE Second Ignition Output (+12volt).
    Did not connect this wire to anything.
    14 Pin Main Harness
    Pin 1: GRAY/BLACK: Option 1 Output (-500mA). Factory arm output
    Din not connect this wire to anything. No Factor Alarm
    Pin 2: Brown Siren Output (+) 3A.
    Did not install siren
    Pin 3: WHITE Left Signal Light Output (+) 10A.
    Did not connect wire
    Pin 4: WHITE Right Signal Light Output (+) 10A.
    Pin 5: ORANGE Armed Output (-) 500mA.
    Pin 6: PURPLE/BLACK Factory Disarm Output (-) 500mA.
    Did not connect wire. No Factory Alarm
    Pin 7: GRAY Dome Light Output (-) 500mA
    Connected to dome light supervision GREEN/BLACK (-) in drivers kick panel.
    Pin 8: RED/WHITE Brake Input (+).
    Connected to Brake WHITE (+) @ switch above brake pedal
    Pin 9: WHITE/BLACK Hood Pin Input (-).
    Did not connect wire No hood pin as of yet.
    Pin 10: GREEN Door Input (+ or -).
    Pin 11: PURPLE Ground When Running Output (-) 500mA.
    Did not connect wire haven’t installed the bypass module.
    Pin 12: YELLOW Generator Input (+).
    Pin 13: BLUE Trunk Input (-).
    Pin 14: GREEN/BLACK Optional Trigger Input (-).
  11. clipser-gs-t
    exactly....
  12. newbie99
    whats exactly ive basically got everything hooked up but a few wires
  13. newbie99
    got the alarm installed by an installer but he didnot do the power trunk and my camera dose not seem to work any sugestions also how would i make time starts on cold nights and auto arming this is what he never mentioned
    PageGuard 8500s 2way Alarm
  14. newbie99
    got everything working on this alarm but the trunk just looking for information on how to hook the trunk up to the alarm so it will work when trunk button is pressed thanks 03 sunfire with page guard 8500s alarm
  15. JMlzT
    JMlzT Full Member
    Connect the trunk trigger wire from the Page Guard Module to the wire for the trunk-release button inside the passenger compartment.
