I have 1 splw-x subwoofer and I need help picking an amp 4 it i did find 2 amps that were in my price range but i need to know which one would be better these r the stats for the sub SPLW-122X • Cloth/Paper Composite Cone • Red Cast Aluminum Baket w/ Diamond Cut Accents • Chrome Back Plate • UV Coated Foam Surround • One Piece Rubber Gasket w/ Color Matched Inserts • Dual CONEX Spiders • Nickel Plated 8 ga. Compression Wire Terminal MAX POWER = 2500 watts RMS POWER = 1200 watts MAGNET WEIGHT = 340 oz FS = 31.5 hz QMS = 4.93 VAS = 2.013 ft3 XMAX = 28.50 mm QES = 0.483 QTS = 0.440 EFFICIENCY = 87.56 dB and here are the stats 4 the 3 amps the first 2 r class d the third one isnt 1. Pyle Car Audio PLAM2001D "Power Series" Class D Monoblock Car Amplifier 2000 Watts Details: ***Class D Monoblock Power Amplifier ***RMS Power @ 4 Ohms: 1x500 W ***RMS Power @ 2 Ohms: 1x800 W ***RMS Power @ 1.3 Ohms: 1x1200 W ***Maximum Power Output 2000W Mono ***Mono Block Sub woofer Amplifier ***Frequency Response 15 Hz-150 Hz (±3dB) ***Output Power @ 14.4v DC, 50Hz 1 Ohm Stable ***MOSFET Power Supply ***PWM ( Pulse-Width-Modulation ) System ***Glass Epoxy PCB ***Silver RCA Inputs ***Custom Terminal Block for Speaker Connection ***Thermal / Overload / Short Circuit Protection ***Variable Subsonic Filter ( 15Hz - 55Hz 24dB / Octave) ***Remote Bass Boost ***Input Impedance: 10K Ohms ***Soft Turn On/ Off ***Advanced Protection Circuitry ***S/N Ratio: >90dB ***Dimensions:9.76''W x 2.28''H x 11.42''L 2. Legacy Car Audio LA1800DBK Black Finish Class D Mono Block Amplifier 1800 Watts Max Details: ***1 x 1800 Watts Max Output ***1 x 900 Watts RMS Output @ 4 ohms ***Fully Adjustable Electronic Crossover ***Variable Bass Boost: (0-12dB @60Hz) ***Variable Subsonic Filter ***Soft Turn On/Off Circuit ***1 Ohm Stable ***Phase Switch ***Variable Gain Control ***Remote Turn On ***Heavy Duty Aluminum Alloy Heat Sink ***Line Out For System Building ***Power & Protection L.E.D’s ***S/N Ratio: >100dB ***THD: <0.04% ***Fully Protected Circuitry ***Dimensions: 11.1''W x 2.2''H x 10''L ***Fuse: 30A x 2 3. Legacy Car Audio LA1270SL Mono Block Silver Finish Car Amplifier 2700 Watts Max Details: ***1 x 2700 Watts Max Output ***Fully Adjustable Electronic Crossover ***Variable Bass Boost: (0-12dB @60Hz) ***Soft Turn On/Off Circuit ***2 Ohm Stable ***Dual MOSFET PWM Power Supplies ***Variable Gain Control ***Remote Turn On ***Heavy Duty Aluminum Alloy Heat Sink ***Hi/Lo Level Molex Input ***Power & Protection L.E.D’s ***S/N Ratio: >95dB ***Frequency Response: 40-150 Hz ***THD: <0.04% ***Fully Protected Circuitry ***Dimensions: 11.1''W x 2.2''H x 13.9''L ***Fuse: 25A x 2 all i need 2 know is which one would b better 4 my sub
I would not buy any of thoses amps. If your looking for a good budget amp id go with Crunch. they are built by the same company that makes hifonics. Also you dont say if your sub is single or dual voice coil.
it has dual voice coil and i am on a budget and these are the only amps i could find in my price range
