I fried the power distribution block?
Discussion in 'Car Stereo Amplifiers' started by SwampLife, Mar 29, 2010.
  1. SwampLife
    SwampLife Member
    I have a cheap amp (Baja HA700M) 700 watt amp that I was using for a 10 in my car. I dont know how it happened, but the area where the power, ground, and remote wire connect. it looks like I melted that area where the power wire is supposed to go into. The plastic around it looks like it exploded. I have a bunch of stuff in my trunk floating around, I think that the ground came undone and touched the power wire, causing it to melt. Is there a way to get that repaired? About how much do you think it would cost? Thanks
  2. jonnyv713
    If its a cheap amp, just upgrade. It wont be worth it to fix it.
  3. MTX4Life
    MTX4Life Full Member
    I had the same situation, only it was a sound stage in my Boss amp.. Good amp, just cheap. I could've bought a whole new Boss amp for the cost to fix the old one.. just save up and get a decent one man.. alot easier, cheaper, and less stressful than blowing one cheap amp after another.
  4. pedro quiroga
    i think this is your problem, not a bad amp at all. i sold a profile amp to a friend of mine that i bought in 92. still works great.
    like it was said you can get another amp for a lil bit more than a repair can cost.
