i blew my subs
Discussion in 'Car Subwoofers' started by waddles, Mar 2, 2010.
  1. waddles
    waddles New Member
    hey i need help i blew my subwoofers they are volfenhagen 12's 1000 watt max 500 rms dual voice coil that are hooked up to 2 ohm and the amp im using is a directed audio 750 watt class d rms at 2 ohm is 400 watts but here is the specs on the subs and amp (subs first)
    * POWER[MAX]: 1000W
    * ALUMINUM CONE
    * 4 OHM + 4 OHM DUAL VOICE COIL
    * ALUMINUM DIECAST CHROME BASKET
    * USABLE IMPEDANCE: 2-8 OHM
    * HIGH TEMP 4-LAYER VOICE COIL
    * DOUBLE DAMPER
    * BUMPED & VENTED T-YOKE
    * DOUBLE STACK MAGNET STRUCTURE
    * PUSH TYPE TERMINALS
    * FREE AIR RESONANCE: 30 Hz
    * TOTAL SPEAKER “Q”: 0.526
    * ELECTRICAL “Q”: 0.614 - MECHANICAL “Q”: 7.698
    * VAS: 56L
    * EFFICIENCY (1W/1M): 89.58dB
    * PISTON SURFACE AREA: 0.0491m
    * DC RESISTANCE: 3.2 OHM
    * DUAL 4 OHM NOMINAL IMPEDACE
    * CONTINUOUS POWER: 500W
    * MOUNTING DEPTH: 160mm
    * MOUNTING DIAMETER: 282 mm
    (now amp specs)
    Dynamic Power Rating: 750 watts
    S/N: > 80 dB
    Freq. Range: 20-250Hz
    Damping Factor: > 50
    Input Sens.: 150mV to 8V
    Rated Power @ 4 ohm: 275 x 1
    Rated Power @ 2 ohm: 400 x 1
    Rated Power @ 1 ohm: 600 x 1
    Crossover: var. 18dB low-pass
    Bass EQ: Yes 8 dB
    RCA Output: Yes, mono
    (also i have two of them both are dead box is pretty small tho it is 14"h 36"l 14"d sealed maybe the box killed them?)
  2. tommy2tone
    tommy2tone Full Member
  3. waddles
    waddles New Member
    ahhh thats probley where i went wrong they are hooked 1ohm but anyway the gain on the amp is 3/4 up and no bass boost was used on amp didnt sound distorted or anything (never sounded peaked is better to say i guess) but from what i hear these subs are crap good thing i didnt pay much for them (they were wired this way when i got them) but they are for sure blown they are rattling if you will (sandpaper on steel)
  4. waddles
    waddles New Member
    now another quick question what would happen to this amp if i had a 2ohm dvc wired to .5ohms or would that be 1ohm? would it kill it i have another sub that is dvc 2ohm it is 2700 max and 1500rms any ideas (sub is a power acoustik mofo 12) (just one in a 2.0 ft ported box)
  5. fstrfvo
    fstrfvo Full Member
    it would be 1 ohm, since your amp is 1 ohm stable go for it.
