how does this look?
Discussion in 'Subwoofer Box and Custom Fabrication' started by cccullen, May 2, 2008.
  1. cccullen
    I was on another forum and this guy was giving free box dimensions so i thought I'd pm him and see what he would come up with for my 13Ov.2's.
    Here's what he said...
    Good Morning, well these subs need a bit less chamber space so the enclosure will be a bit thin, based on .35^3ft sub & bracing displacement, and .75" thick MDF, build it 14"H x 49"W x 14.25"D, this will give you 4.381^3ft gross vol. Build your port, 12.5" x 3" x 20.1"long@35Hz. This will put you at 3.565^3ft net yield. This design will do the job very well.
    How does that look? does it sound right for what the 13Ov.2's need? or should I pay no attention to it?
    comments....
  2. Ranger SVO
    Looks like a well thought out box. Personally I might tune a little higher but the most important factor, size is there.
    I would go with that design as is.
  3. cccullen
    thanks ranger, I really don't know much about boxes..
  4. aznboi3644
    looks good...
  5. cccullen
    should i put the port in the middle instead? subs and port are firing to the rear. I was thinking about just putting the port in the middle but what kind of changes would i have to make in order to do that?
  6. aznboi3644
    cumulative port area would still have to be the same
  7. cccullen
    I know that you are aware that i'm really in the dark about these things. so if i want the vent in the center of the box i would do it 12.5" x 3" then have two 10.5" boards for the port2 measurements? is that right?
  8. electrolytic
    electrolytic Full Member
    13Ov.2 Subwoofer
    Enclosures
    Spec 13Ov.2 Subwoofer
    Sealed ( small ) 0.7cF
    Sealed ( ideal ) 1.0cF
    Sealed ( large ) 1.25cF
    Vented ( ideal ) 1.5cF Tuned to 30Hz
    Vented ( DDLoud) 1.5cF Tuned to 35Hz
    Specifications Theile Parameters
    Qts: .28
    Qes: .30
    Qms: 3.3
    Fs: 21 Hz
    Re: 8.3
    Vas: 176 L
    Mms: 195 g
    Bl: 21.7 T*m
    SPL: 89.1 dB
    Sd: 545 cm^2
    Xmax: 18.3 mm
    Voice Coil: 62.5 mm
    Magnet Width: 6.000"
    Cutout Diameter: 11.000"
    Mounting Depth: 6.600"
    Weight: 25 lb
    Total Height: 7.600"
    Displacement: .06 ft^3
    Outside Diameter: 12.375"
  9. electrolytic
    Looks almost dead on, he must have used bassbox. Do you have 49 inches across in your trunk? seems too big to me. I can make a smaller box if you need it.
  10. electrolytic
  11. electrolytic
  12. electrolytic
  13. cccullen
    got a new design made...
  14. electrolytic
    nice, sure it will fit? lol. What amps are you using again?
  15. cccullen
    I'm sure it will fit. the width of the expedition is 49". The box is 48". I did the measurements twice to make sure. lol
    I'll be using an eD NINe.1 for the subs. 2 13Ov.2's DVC 4ohm. so i'll run them at 1ohm. Everything should be here in June. They were all shipped out last week. Takes a month to ship them over here. I'm going crazy just listening to my 2 coax speakers in the rear doors... After i took out the amp and sub in my car (sold it) I never got around to connecting the the components up front.
