How do i....
Discussion in 'General Car Audio Discussions' started by siccrownvic, Oct 7, 2009.
  1. siccrownvic
    siccrownvic Full Member
    How do i wire my door and back deck speakers to my amp in the trunk? Do i have to fish the wires throught he whole car?
  2. Lazy Eye
    Lazy Eye Full Member
    Yeah, would need too run new wires from each speaker back to the amp
  3. siccrownvic
    Would the deck control the speakers then?
  4. Lazy Eye
    I take it that you have an aftermarket deck right? If so does it have a set of outputs on it? like where you plug in a set of rca's?
  5. siccrownvic
    Yes, they are hooked up to the amp that powers my subs.
    So i just have to split the existing power wire, set rcas from the existing amp to the second one and wire the four speakers to the second amp?
  6. cccullen
    the most easy thing to do is get the speaker connections from where they'll connect to the deck. Then run the speakers wires from there to your amps along with running the rca's. That's the quickest way of doing it.
    since you'll run two amps now, i would suggest getting a distribution block to split the power runs into 2.
  7. siccrownvic
    Alright, that sounds easy enough for me to do.
    Ill try this weekend and report how i goes.
    Thanks
  8. Lazy Eye
    Try to take some pics of the install to, we like pics around here
  9. siccrownvic
    Pictures to follow some time this week.
