Hooking up a sub in my Astra...
Discussion in 'Car Subwoofers' started by MysteryNick, Mar 9, 2010.
  1. MysteryNick
    MysteryNick New Member
    Ez guys,
    Once again, I find myself clumsily poking around in the darl for an illusive hole...:rolleyes: Does anyone know where you poke the power cable through at the front of a Vauxhall Astra (estate 1.6L petrol. V reg) to hook up a sub (in the boot) to the battery? There doesn't seem to be anywhere obvious for you to run cables through... I've hooked the sub up to my cd player without too much trouble. Getting any power to the thing is proving a pain in the ass tho!
    Cheers
    Nick
    look for any wire loom running thru the firewall and see if you can stick a wire thru its grommet.
    i used my steering column's grommet.
  3. MysteryNick
    Thanks for that mate. I'll give that a try
  4. pedro quiroga
    no problem. hope it works out for you.
