I was looking at a hitron amp and i was wondering if they were any good Hitron HNA-435 - 1200W 4-Channel Power Amplifier • 85W x 4 chan. @ 4 Ohms • 110W x 4 chan. @ 2 Ohms • tri-mode capability • dual color indicator LED • MOSFET power supply • overload protection - , Car Amplifiers, Multi-channel Amps - Sonic Electronix if they are can i make that a two chanel amp out of that
well i dont know if they are good but yes you can make a 2 channel amp out of it by bridging it but you need a min impedance of 4 ohms
what do u guys recomend then i want something around 100 bucks and needs to be from 800 to 1000 watts rms
Power Acoustik TS960-4 4 Channel 960W Plasma Amp NEW 06 - (item 250149725969 end time Aug-02-07 20:09:10 PDT) i have one similar to this and it puts out at least 400 watts.
so you just want a 4 ch? hit up ebay and slect the amp section.look under 4ch's eBay - Multi-Channel Car Amplifiers Finder - Find IT on eBay
well i havent decided if i want dual or single voice coils what is better and they are 4 ohms per coil
no.your post was just somewhat confusing.sorry. the subs you buy will determain what amp you have to get.
so if i get the dual voice coils should i get about a 800watts rms amp or what do u suggest. or if i get one of these subs would it sound good in a trunk of a car on a about 400 to 500 rms amp
