Hifonics wiring
Discussion in 'Car Stereo Amplifiers' started by smartmlp, Dec 13, 2006.
  1. smartmlp
    smartmlp New Member
    I recently acuired a "Hifonics Titan TXi 7506" amp, I plan to use it with the subs I already have (2 cheap audiobahn AW1251T 12") and I was wondering if I can run this amp by running the subs like this Diagram on the top right that results in 1 ohm.
    Also, is this a good amp in general?
    Thanks in advance.
  2. smartmlp
    smartmlp New Member
    If no one has any suggestions, I’m going to go ahead and wire it like this and hope it works out.
  3. TheViking
    that should work, 1 ohm, 1 channel amp......yep, should be fine
