Hifonics BXi 1210D AMP???
Discussion in 'Car Stereo Amplifiers' started by napiliboy47, Mar 4, 2010.
  1. napiliboy47
    napiliboy47 Guest
  2. fstrfvo
    fstrfvo Full Member
    I have that amp but its an earlier model, its a very strong amp, runs cool and really bangs the woofers. I had it pushing 2 ppi dcx 124 subs with no problems. I think it will really push that soundstream hard.
  3. napiliboy47
    napiliboy47 Guest
    how many watts were you giving ur woofers and at what ohms?
    it says i will get 1200 watts at 1 ohm but i heard they are overrated.
    how much TRUE watts do you think ill get?
  4. tommy2tone
    tommy2tone Full Member
    I had the bxi1208d and it tested out at a rms of 765 or something like that at 2ohms.Rated at 900 rms at 2ohms.If I remember right my voltage was 13.4.I ran mine at 2ohms for 6 months and then at 1ohm for about 4 months with no problems at all.My friend who tested the amp moved so I never tested with a 1ohm load.
  5. napiliboy47
    napiliboy47 Guest
    whats the difference in running amps in different ohm loads? (not including watts)
    also, anyone got comments about this amp or the T5 sub?
  6. fstrfvo
    fstrfvo Full Member
    I had it wired at 1 ohm, no problems at all. I think those subs are rated at 1000 watts each.
  7. fstrfvo
    fstrfvo Full Member
    as for ohms the lower the number the more current the amp is asking for. Think of it as a garden hose, a normal hose would be 4 ohms, then a fire hose might be 2 ohms and a fire hydrant might be 1 ohm, the bigger you get the more water you can flow, but of course you need something to pump more water when the hose gets bigger. So the lower impedence (ohms) your amp is running the more current its asking for. hope that makes sense, i tried to explain it in simple terms.
  8. napiliboy47
    napiliboy47 Guest
    that definitely makes sense.
    what do you guys think about this setup?
  9. tommy2tone
    It should work just fine.I personally don't care for the sound of square subs,but hey to each his own.
  10. Kvo_8
    Kvo_8 Full Member
    i heard for 2010, hifonics is actually putting out their rated power at 14.4v..
  11. tommy2tone
    That would be good for hifonics.I really liked my amp,but it did draw alot of power.My lights dimmed really bad with that amp,and now only a little at a stop light(with a alpine m1000).
  12. napiliboy47
    napiliboy47 Guest
    they're not square. lol. and also thats why im getting the 1200watts at 1ohm b/c i know they are overrateed and the sub only takes 900 RMS
  13. napiliboy47
    napiliboy47 Guest
    i was thinking bout getting the 2009 version.
    Im on a really tight budget
  14. napiliboy47
    napiliboy47 Guest
    more comments pls
  15. napiliboy47
    napiliboy47 Guest
    where is a good place to buy this amp? Where have you guys bought them?
  16. I had my Hifonics Brutus BXI2010D bench tested at 2 different voltages.
    1: 14.4 volts 4 ohms = 662 watts, 2 ohms = 1401 watts, 1 ohm 2024 watts
    So at 14.4 it put out the rated power.
    2: 13.8 volts 4 ohms = 529 watts, 2 ohms = 1098 watts, 1 ohm 1878 watts
    A little overrated a 13.8 volts but thats normal. For the $$ imo their the best bang for your buck amps that are out there. I paid $248 brand new w/ 2 year warranty. It pushes my Type R 1022D's great, I run at 2 ohm's and I know their getting their rated power if not a little more. Hope this helps...
