heres my setup right now
Discussion in 'General Car Audio Discussions' started by crazywhiteboy91, Dec 15, 2009.
  1. crazywhiteboy91
    crazywhiteboy91 Full Member
    ok got an MA audio competition series amp powering my 2009 memphis mojo 12'' in a ported box built to specs. the sub is dvc 2ohm. the amp pushes it only hooked up to one voice coil but i had 2 powerbass extreme 12''s on a 500 memphis amp an they were a little louder. heres the stats on my amp. do you think with a better amp i would get alot louder?
    Model: MA Audio M1900XE
    XE Series 1000 Watt 1 Channel High Performance Mono Block Car Amplifier
    1 x 1000W RMS @ 2 Ohm Mono
    1 x 500W RMS @ 4 Ohm Mono
    Fully Unregulated MOSFET Power Supply
    2 Ohm Mono Stable
    Thermal, Short, and Overload Protection Circuitry
    Power/Protection LED Indicators
    Stainless Steel Finish Heat Sink
    Double Sided Black Epoxy PCB Board
    High Performance RCA Jacks and Block Terminals
    Low Level RCA Inputs/Outputs
    Selectable LPF/FULL/HPF Crossover
    the 2 12's were louder cause you had more cone area. if you had 2 D2 subs you can get it way louder than the previous set up.
    or you can get a 1Ω stable amp and send it more power.
    the choice is yours. i saw what the sub cost. you can get a good 1 ohm sub amp for around the same price.
    you can do either.
  3. crazywhiteboy91
    yea i didnt pay near what the dealer sells for i got it offa kid with that ma amp. the amp used to be mine then i sold it and bought it back. i only gave 420 for both of em. i was plannin on buying a memphis pr 1.1000 to power it at 1 ohm.
