i am having problems out of my system. the freakin door speakers are makin an awful screeching noise every time my cd skips or somethin i really dont know. and when i turn up the volume, the sub will continuously cut out and on. can someone tell me what is goin on
Check all of the electrical connections behind the deck, under the hood, where the amp(s) is/are located. Just check everything and make sure the connections are good clean and tight. Check -remote lead -power lead -speaker wires -battery terminal connection of power wire -etc etc. What is your gain set at? What is the impedance that your amp is wired at? Amp could be going into protection.
