help with port
Discussion in 'Subwoofer Box and Custom Fabrication' started by mrmizcue, Sep 28, 2007.
  1. mrmizcue
    mrmizcue Full Member
    i just wanted to run this by you guys to see what yall come up withi have very little trust in BB6....the box outside is 39cm x39cm x90.9cm... mdf is 1.8cm....tuned to 38.22 port is 30.5cm x 4cm and the length i get is 35cm. 2-12 subs each with a displacement of .094 cf.... .188 cf total. if you look there is a 3.5" difference between MY BB6 and win-isd.
  2. mrmizcue
    i am wanting to use a "T" port b/c of the box and everything else...i would measure it from centers... right? then both sides of the T...right and left ...would be the same length
  3. jmenace_thakidd
    jmenace_thakidd Full Member
    yea i had that problem getting different thing from the 2 programs but the only thing i could see is that win isd doesnt subtract port area and it hadd something about a end correction and i have no idea still wat that is
  4. mrmizcue
    but in both programs the net volume is the same. 3.5" is alot.....too much to build a box with that much difference
  5. aznboi3644
    do the math like i showed you in the other thread and check
  6. mrmizcue
    i do not understand what some of the symbols are otherwise i would....sorry
  7. jmenace_thakidd
    lol yea i need to learn that so i can check my work also
  8. aznboi3644
    well to use that you must convert your port area to a round port with the same area.
    I've never been 3.5 inches off before when comparing some online calcs to winISD
  9. mrmizcue
    ok...after looking closely at the formula it is easy...no problem....thanks again!!!!! i will make a spread sheet for your formula Aznboi and post it. i already did the one from the12volt.
  10. jmenace_thakidd
    your gonna have to teach me the formula then
  11. mrmizcue
    i seemed to figure out the problem i was having in BB6. I am useing a slot port and when i convert it to round the area is the same but not the primeter. I design air (hvac)systems and that i know that round duct has less drag/friction loss than square duct. So i can only reason that BB6 also knows this and is adding length to compensate for the drag/friction loss. Does that soud right or does it seem that i just pulled that out of my ass?
  12. aznboi3644
    round ports do have less laminar resistance
  13. mrmizcue
    nice word...laminar.....i was going to use "laminar flow" but did not know if anyone would know what i was talking about
  14. electrolytic
    electrolytic Full Member
    huh? lol Why are you converting? Just curious, bassbox does it for you round or square ports
  15. aznboi3644
    laminar is a cool word haha
  16. mrmizcue
    i was having with BB6 giving "wrong" port length's so i reinstalled it and was wanting to check to see if the problem was fixed...so i did it old school and the port needed to be round. i did not understand why the length changed going from a round port to a slot port. In my case the slot port was 1.75" longer. BB6 know's that there is more primeter with a slot than with a circle....so there is more laminar flow. that is where the extra length comes from.
