Today I decided to move my amp a little bit, so I un-hooked all of my wires safely and moved the amp where I wanted it and hooked everything back up.. well now it's not working, the amp will power on and stay on but the subs do nothing! make no noise, so I swapped out the RCA's and still nothing.. well after messing around with it for a little bit I changed the RCA's again and they started to work a little bit, but barely hit.. The amp is getting full power and everything is the same as it was before I moved it which is what confuses me! nothings changed? I checked the gains and they were all correct! So now I'm completely lost! Can someone please help me out? It's a fusion amp (NV-2500AM)
ah... classic... recheck your power and ground wires.. check all connections... something came loose when you moved it... it's a good idea to check you connections at least once a week too, just to make sure nothing is starting to get loose. Even if the amp has power doesn't mean it will work properly... check your power wire at the amp, check your ground at the amp and the grounding point and just for kicks check the REM and the speaker connections inside the box and at the amp.
I got it all fixed although I'm still not sure what the problem was lol.. I just put everything back to how I had it before, I checked all the wires and connectors and everything was fine.. but I'm back to slamming again so it's all good! haha
