Help wiring
Discussion in 'General Car Audio Discussions' started by 86capri, Sep 26, 2009.
  1. 86capri
    86capri New Member
    I have four kicker s8l72 and a Hifonics txi7508 and wanted to figure out how to wire them up to get the most power out them using all 4 subs and nd another using 2 sometimes I take out 2woofers for trunk space thanks in advance
  2. cccullen
    here are the specs for your Hifonics amp:
    # RMS Power Rating:
    * 4 ohms: 325 watts x 1 chan.
    * 2 ohms: 500 watts x 1 chan.
    * 1 ohm: 750 watts x 1 chan.
    now, your amp isn't enough to push the L7's but it will do. your going to have to wire the subs into a 1ohm impedance so you'll be at 1ohm or 750watts.
    you can do so by wiring them like this:
  3. cccullen
    or if you'll only use two of the subs then you can only do so at a 2ohm load. If you have the space though and you don't want to add another amp then i'd say stick with all 4, more cone area would equal more bass! :)
  4. 86capri
    86capri New Member
    How about if I use a jl audio 450/4
  5. pedro quiroga
    750 watts to 4 8's is a good amount of power. im running 500+ watts to my 8's and its loud.
  6. 86capri
    86capri New Member
    How do I wire them to the jl450/4
  7. cccullen
    huh? i thought you were going to wire them to a Hifonics txi7508
  8. 86capri
    86capri New Member
    Yeah but I also have a jl 450/4 and wanted to see wich one would work better but need help wiring up to the jl
  9. cccullen
    I'd run the subs off the hifonics and use the JL for your mids and highs.
