Hello, I've purchased 2 10" Scosche 150 watt RMS (each) subs. The sub terminals have unfamiliar connectors and also the enclosure box has slightly different ones on the inside. can someone identify what connectors I need to wire the sub to the box? and also how I would secure the connection (I don't have a saudering iron)
your second pic did not enlarge what was shown. it went to an angel pic... repost it again so we can see what you speak of.
re posted 2nd picture.. Please help with name of connectors if you can.. I'm ****ed off that neither the sub enclosure or the subs that I bought listed what sort of terminal connects I needed to buy in order to hook these up... i'm sure the exact size won't be known, but at least if I had a name for these 2 connectors, i'd know what to ask for when I go back to the place I bought them at. thx so much
Based on what I am seeing, the connectors for these are sold in Walmart. Another option would be to string the wire through the holes like thread through a needle. I am not sure what the connectors are called (I think they are called quick female disconnects) here's a pic of what they would look like . Hope this helps.
Hope this helps! Based on what I am seeing, the connectors for these are sold in Walmart. Another option would be to string the wire through the holes like thread through a needle. I am not sure what the connectors are called (I think they are called quick female disconnects) here's a pic of what they would look like View attachment 2992 . Hope this helps.
