Hey My sound system is soundin prety crap cos gains n all that are messed up cos i had a bad attempt at tryna fix em, so any1 know wat i should be doin to get the settings rite to get best out my system? This is the equipment im using Ive got JBL Sub 15" 1200 watts GTO1502D JBL Amp GTO 200 400 Watt Max 2/1 channel JBL Amp GTO 400 600 Watt Max 4/3/2 channel Kenwood 6" x 9" KFC-M6940ie Pioneer Headunit DEH-P8600MP Sub Box and Wiring and Facia and other things requied. Also how do i check my component on the drivers door, (ive got a ford focus) as its not working, its jst not on at all, the tweeter works tho but not the component, i dnt think its blown out as would it atelast work , wouldnt it? Ive checked all the wires going into amp as theese r only onces i can get access to and they seem to be ok. Any advice and tips would be greatly appreciate, thanks as i would like to resolve this prob asap,
okay.. first of all, it's a good rule of thumb to start at zero with everything on the HU. turn the loudness function and bass boost off (if it has one). The jbl sub is a svc, right? what style box is it in? I'd hook the 600w amp (bridged to 1ch) to the sub. use the 400w amp for the 6x9's, set it to hpf, and keep the level under 1/2 to begin with. on the sub, adjust the lpf to about 1/8 turn past the lowest setting (it's a 15" sub, you don't want it hitting the 200hz frequencies) and set the gain at about 1/2.. go from there and see if you can acheive the desired sound from the controls on the HU.. if not, go up or down from there. as for the speaks, if the component is not functioning at all, then either the vc is blown or a wire has become disconnected. check that all of your wiring is secure (are these stock components?) and please in the future, take the extra time to spell out your words properly.. ghetto posts can be difficult to understand, and we want you to get the help you need.
