help please
Discussion in 'Car Subwoofers' started by Dmatt, Oct 21, 2009.
  1. Dmatt
    Dmatt New Member
    ok so i am buying 3 kicker cvr's 4ohm. i have a monoblock 600 rms alpine monoblock amp as of now. i have already made the box for the subs, however i know my amp isnt strong enough to run all 3 since they are 400 rms each sub, is it possible to run 2 of the subs off of the 1 amp i have now and then get a smaller one and run the other sub, even with them all in the same box? or will this make them sound terrible
  2. bhawk93
    bhawk93 Full Member
    it is possible to do that all you have to do is hook the negatives on the two subs together and run a third wire from it, then do the same for the positives. Also it shouldnt make them sound terrible if you hook the third to another amp.
  3. Kvo_8
    Kvo_8 Full Member
    are they in 3 seperate boxes?
