basically im looking to know will this amp be powerful enought to work with the following sub and speakers. its nothing special but just passed my driving test and just looking something affordable and good build quality so was reccommended Fli. Fli 900s Amp •Type: 4/3/2 Channel •Class: AB •4 Ohm Stereo: 4 x 100W RMS •2 Ohm Stereo: 4 x 115W RMS •4 Ohm Mono: 2 x 225 RMS •2 Ohm Mono: N/A •Max Power: 900W •Frequency Response: 20Hz-20KHz •SNR: 92dB •THD: 0.2% •Bass Boost: 0-12dB •HPF: 45Hz-300Hz •LPF: 45Hz-300Hz •Input: 2 or 4 Channel FLI Trap Twin 12" 2000W Bass Enclosure •Model – Twin Passive 12 •Driver – 2 x Frequency 12 •Enclosure impedance – 4 Ohm •RMS power – 800 watts •Peak power – 2400 watts •Minimum Input – 400 watts RMS FLI Audio FI9 •Type : triaxial •Configuration : 3 way •Speaker size : 6x9" (160 x 230mm) •RMS power : 100 watts •Peak power : 375 watts •Minimum input : 30 watts RMS •# Sensitivity: 90 dB •Frequency response: 45Hz - 20 Khz •Mounting Depth: 79mm •Recommended amplifier : FL400S/FL900S any help given will be well apreciated
