Hey, basically i want to put a system in my Yukon XL 2002, i want something that has a bass that hits deep, but first i dont know what i need, and second i dont have a huge budget, so any help is appreciated, sorry if this is in the wrong section
Im in class right now, but I will be more than happy to help you out later. What size subs do you want? What do you want to spend? Do you need to keep space in the back? How many subs do you want? Do you want to change your speakers up front? G3 had good experience with these subs http://www.sonicelectronix.com/item_9357_Hifonics+HFi+12D4.html I will get you some more links later today though.
hey, thanks Well, i would like to spend the least possible, but probably in the 200-300 dollars range... I dont really need a ton of space in the back, for a box maybe? Im not really sure how many subs is good to have, like what would be the benefits of having more or less? and, if its in the budget, yea i would like to change the speakers up front, my problem is i like to play music with bass, so ive blown out the factory subs, and the front speakers and crappy
300 for subs and amp or just subs? and can you provide the dimensions where your box will be going in inches and WxHxD format. With those I can get a much better idea as to what you'll need.
um, it would be nice if i could spend 300, for subs and amps, but a little over would be fine And, im not really sure what dimension your looking for, like the size of the whole back area?
Welcome!!! first, just measure the area where you have the space that you can give up. So, you want to spend only 300 for subs, amp, speakers up front and a box for the subs along with wires? That may be a little tough but we may be able to work on something for you. Are you planning to install that yourself?
i was thinking some hifonics subs like jonny said, a PA amp and some phoenix gold component speakers up front. what do you think? jonny? G3? Pedro? Azn?
this may go a little over 300 but you may want to look at it. Subs: 2 12"s http://www.sonicelectronix.com/item_9357_Hifonics+HFi+12D4.html Component speakers for front http://cgi.ebay.com/PHOENIX-GOLD-RSd-65cs-6-5-COMPONENT-SPEAKERS-RSd65cs_W0QQitemZ400008802138QQcmdZViewItemQQptZCar_Speakers?hash=item400008802138&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A1|240%3A1318 Amp for Sub http://www.sonicelectronix.com/item_9795_Phoenix+Gold+Ryval+V8001.html
i think those are all good choices CC. dont forget your install budget. wires, line converter or rca's if you have an aftermarket radio.
looks good to me. Sorry, I woulda jumped on it quicker but i just got back from a party. Umm, ya, just build the right box and it will slap!
put those hifonics in a box thats around 5 cuft and tuned low and you'll have yourself a window flexer.
make it yourself. ask help here for a design for the box. in order for the guys to help you out here, they'll need to know what sub/s your going with and the max dimensions you are willing to give up for the box.
http://www.termpro.com/articles/buildbox.html read that to get associated with the process and give us your max dimensions and we'll worry about the volume and tuning.
