help needed
Discussion in 'Car Subwoofers' started by jmenace_thakidd, Feb 27, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    is this amp any good
    spl audio dk2600d mono
    Hi Speed Digital Circuitry
    Fully Regulated PWM Power Supply
    Four Way Protection Circuit
    1 Ohm Stable
    Bridging Synchronization
    Variable Low Pass 50Hz-150Hz
    Variable Subwoofer EQ @ 45Hz
    Variable Subsonic Filter 15Hz-40Hz
    Phase Switch 0-180
    Remote Dash Mount Low Level Gain Control With Cable
    Frequency Response: 15Hz-150kHz
    S/N Ratio: 100dB
    THD: 0.5%
    System Distress Indicator
    Inputs Sensitivity: 200mv-8V
    Dual Mono Speaker Output Connectors
    Gold Plated Heavy Duty Power & Speaker Terminals
    Specifications:
    1 ch
    4ohm RMS: 1100
    2ohm RMS: 1600
    1ohm RMS: 2000
    Max: 2600
    Dimension: 15x2.7x11 (W"xH"xD")
  2. jmenace_thakidd
    damn cantget one reply
    it must be cause im new
  3. daimond16
    daimond16 Full Member
    its ok nothing special
  4. jmenace_thakidd
    just wanted to know what people thought
  5. aznboi3644
    its not very good...for a little more money you can get better quality.
  6. jmenace_thakidd
    i think i have found wat i want
    2 kicker L7s
    powered by
    2 kicker zx750.1 AMPs
    both subs and amps RMS @ 750
    wat do u guys think about that
    please let me know
  7. aznboi3644
    awesome setup...what is this going in??
    What electrical upgrades have you done??
  8. jmenace_thakidd
    going in a 02 galant havent done anything yet got any suggestions for that system ima be running please fill me in im new to this
  9. aznboi3644
    going with a possible 1500 watts rms of unrated power....I'd upgrade the big three with some 0 gauge wire...Welding cable is cheaper and will work perfectly.
  10. jmenace_thakidd
    big 3 with 0 gauge wire thats wats up ima do that this weekend
    thanks again man im glad i can here for help
  11. aznboi3644
    no problem
  12. jmenace_thakidd
    where can i get a good wiring kit to run both these amps
  13. jmenace_thakidd
    got it had to add that to my favorites
  14. DaveDSMer
    DaveDSMer Full Member
    thank you come again
  15. jmenace_thakidd
    Question????
    since im running two amps
    shoulg i use 0gauge from battery
    to a distribution block and run 4
    gauge to the amps?
    ima be using 2 kicker zx750.1's
  16. pedro quiroga
    i always say get the best you can afford.who knows maybe one day you will want to upgrade.then you wont have to change wires again.
  17. DaveDSMer
    I prefer to use distribution blocks when using more than 1 amp to clean up the install.
  18. jmenace_thakidd
    kool i thought that would be better just wanted some input from the PROs
  19. pedro quiroga
    .i've just been into this stuff for 20 years.
