help me out
Discussion in 'Car Stereo Amplifiers' started by Adrian, May 17, 2006.
  1. Adrian
    Adrian Full Member
    alright i jus bought 2 10" Kicker L5 4 ohm, well i wanna get a mono amp but jus havent found the right 1
  2. ramos
    ramos Full Member
    How much you looking to spend ? Bunch of amps that will do the trick. Gonna need something that can handle a 1ohm load. Cause the power your looking for at 4ohm is gonna be hella expensive :)
  3. peter_euro
    peter_euro Full Member
    not really, refurbed Cadence Z9000 should put out about 900 watts bridged at 4 Ohms conservatively speaking...;)
  4. ramos
    ramos Full Member
    Der, he said l5's not l7's my bad :)
  5. LunarEclipse
    LunarEclipse Full Member
    i love the soundstream 900D....they're only $300 if you can still find them now....They're 900 watts RMS 2000 watts max and 1 ohm stable
  6. Adrian
    Adrian Full Member
    wat if i put 1 of these 2 each 1 Sony XM-DS1300P5
    200 watts RMS x 1 at 4 ohms
    400 watts RMS x 1 at 2 ohms
    Class D design
    variable low-pass crossover (50-300 Hz at 12 dB per octave)
    variable bass boost (0-10 dB at 40 Hz)
    subsonic filter (for cleaner performance)
    speaker- and preamp-level inputs
    preamp outputs
    remote bass control
    gold-plated connectors
    requires 4-gauge power/ground leads ? wiring and hardware not included with amplifier
    11-5/8"W x 2-1/4"H x 11-1/2"D
  7. Adrian
    Adrian Full Member
    or how about this 1 2 power both of them
    Kenwood KAC-9152D
    1800W Mono Power Amplifier
    RMS Power Range : 500-900 Watts
    Number Of Channels: 1
    Maximum Power: 1800 Watts
    Low Frequency response: 50 Hz
    High Frequency Response: 200 Hz
    Built In Crossovers: Yes
    Channel Separation: YesMono channel Power Amplifier with Dual Mono Drive Function
    RMS Power: 500W x 1 @ 4 ohms
    RMS Power: 900W x 1 @ 2 ohms
    RMS Power: 900W x 1 at 1 ohms
    RMS Power: 900W x 2 at 4 ohms (Dual Mono Drive)
    Aluminium Die-casting Heat Sink
    Detachable Aluminium Dress Plate & Top Panel Control
    Dual Mono Drive (Bridged Connections of KAC-9152D x 2)
    Gold Plated Input/Output Terminals
    Single Side Exposure of Terminals for Multi Installation
  8. Hautewheeler
    Hautewheeler Full Member
    I would recommend the kenwood anyday over sony
    you might also check out the alpines, hifonics, or jbl gto series
  9. ramos
    ramos Full Member
    Of those two hands down the kenwood. I have a thing against any sony product. Short of the older es stuff. I have had problems with almost every piece I owned or installed. ~450w each should be nice, gonna put them in a ported enclosure ? :)
  10. Adrian
    Adrian Full Member
    jus how would i set it up
  11. aznboi3644
    how do you want it set up? ported or sealed? inverted or not?
  12. ramos
    ramos Full Member
    Ported I hope, the l5's and l7's really come alive ina ported enclosure. Inverted or not really makes no difference other than aestethics (sp?) :)
  13. Hautewheeler
    oh, yes... and try them in a correctly engineered and built right bandpass, and watch the heads roll:eek:
  14. aznboi3644
    Are you looking to build your own enclosure and want us to help you design one?
    Cuz if you want ported than go ported. I personally prefer l5/l7s in a ported box. Sealed sounds a little too mushy to me.
  15. Adrian
    Adrian Full Member
    i always did want 2 design my own box but always thought i would **** it up, i had alot of ideas
  16. aznboi3644
    Well the only way you'll learn is to try it. We'll all be happy to help you design a proper enclosure for you. Just tell us what kind of space you have to work with (width, highth, depth)
