Whatsup, I'm pretty new to car audio and have a few questions about what would be the best speaker enclosure for my subs. The system will be going in a 2000 chevy silverado single cab. I own: -2 12" Kicker Comps Impedance 4 ohms Sealed Box Volume (cubic feet) 1.25 - 3.5 Ported Box Volume (cubic feet) 1.75 - 2.25 Port diameter (inches) N/A Port length (inches) N/A Free-Air Yes Dual Voice Coil No Sensitivity 89.1dB Frequency Response 27 - 500 Hz RMS Power Range (Watts) 50-150 Peak Power Handling (Watts) 300 Top Mount Depth (inches) 5 13/16 Bottom Mount Depth (inches) N/A Vas (liters) 127.65 Fs (Hz) 26.5 Qts 0.427 Xmax (millimeters) 9.76 -Kicker ZX300.1 MONO D AMP I've currently got them hooked up to a zx300.1 amp in some junk single boxes and they barely hit. I found these two pre-fab boxes and I was wondering if anyone could tell me which one would give me the best spl without losing to much sq. Any feedback is greatly appreciated. First box: http://caraudiofactory.com/502x12-spl-sub-box-p-143.html Second Box: http://phoenix.craigslist.org/ele/689446645.html Specs for second box: Type: ported Profile: wedge Carpet: black Terminal: push post MDF Body: 5/8” - 15mm MDF Baffle: 5/8” - 15mm Volume (cu ft) - 2 Volume (liters) - 56.6 Tuning (hz) - 45
They both look like run of the mill prefabs to me, but if I were to choose between the two, I would chose to build my own. The first one, the port would fire into the seat. I'm not a big fan of firing a port into a seat. Second, its tuned to 30 Hz. A 30 Hz wave is around 450-inches long. Even at half wave, it will never fully develope in you standard cab truck. Tuning is way wrong for a truck The second one is barely a better choice. Its made of 5/8-inch MDF. We need 3/4-inch for any decent box. It don't say what its tuned to, but if its tuned between 35 - 40 Hz it would be a better match to the size of the cab in your truck. So I really don't like either box.
ranger the second one says it is 45hz. but i agree with ranger, juust build your own, it will sound a ton better and you can also take some pride in the box.
hmmmm i'm sure a gave you a link to probox. right now thats the only prefab i've heard people rave about. when i bought mine i came back to the shop to get some other gear and some thought i had a pair or 12's in my hatch. even the owners brother was suprized. cause he thought i sold the box and went with something else. http://www.proboxrocks.com/products/enclosures/unloaded/chevy/99CRC210/index.shtml
look into obcon.com they have deals on stuff that was just in show rooms and faded carpet but are technicaly new their main is A class and the discouhnted is B class i highly suggest checking them out their GZ's boxes they hve one that is one of the loudest compitition box in the nation that you can buy. lil big but very very very loud. i have one that is louder than stereos with 2 12" 3 12" and even 4 12" speakers with my one 12" i had that was a kove. is see you have a single cab though but they have others to look at for $h!t$ and giggles
