Help me build a great sealed enclosure for a single 12" subwoofer.
Discussion in 'Car Subwoofers' started by nexttothemoon, Jan 3, 2010.
  1. nexttothemoon
    nexttothemoon New Member
    I've just bought a new Pioneer TS-W308D2 dual 2 ohm VC subwoofer. This is the first sub I'm building an enclosure for so I wanted to keep it simple the first time around and stick with a sealed box to keep things easy and relatively foolproof. I may go ported in the future but that's another build for another time.
    I have two different 2 channel amps (Kenwood KAC7204 ~500 RMS bridged 4 ohm for the subwoofer and an Earthquake T1000W/2 ~200 RMS x 2 channels 4 ohm for the 6.5" comps that I'm putting in the front doors (I'll keep the gains turned well down on the amp to the 6.5 comps).
    I've looked at the Pioneer manual for the sub and it has the following stats for a sealed enclosure:
    Minimum Sealed enclosure size: 0.85 cubic feet
    Maximum Sealed enclosure size: 1.75 cubic feet
    Recommended Sealed enclosure size: 1.25 cubic feet
    These sizes include the speaker displacement.
    Here are all the Thiele stats for the sub:
    Nom. Dia.(In) 12
    Qts 0.48
    Qms 14.11
    Qes 0.50
    Fs [Hz] 33.7
    Vas [l] 36.16
    Vas [ft3] 1.28
    Vd [l] 0.400
    Vd [ft3] 0.01412
    Sd [m2] 0.04597
    Sd [ft2] 0.495
    Revc [Ω] DUAL1.5
    Levc [mH] (2000Hz) 2.18 (4Ω) 0.65 (1Ω)
    Xmax [mm] 8.7
    Xmax [in] 0.34
    Zmax [Ω] 99.13 (4Ω) 24.81 (1Ω)
    BI [Tm] 16.07 (4Ω) 8.04 (1Ω)
    Rms[Ns/m] 2.773
    Mms [g] 184.95
    Cms [m/N] 0.00012
    Mg.Wt.[g] 2350
    Flux Density [Gauss] 6800
    Hag [mm] 10
    Hag [In] 0.39
    Hvc [mm] 27.4
    Hvc [In] 1.08
    VC.Diameter [mm] 55
    Eff [%] 0.27
    S.P.L. [dB] 91.0
    R.M.S.Power [W] 400
    M.M.P. [W] 1400
    Sp. Displacement [l] 2.16
    Sp. Displacement [ft3] 0.076
    Recom. Enclosure [l] 35.4
    Recom. Enclosure [ft3] 1.25
    F0 (in Cabinet) 47.9
    Q0 (in Cabinet) 0.682
    I also ran the numbers through WinISD and it calculated that the optimal sealed enclosure size for this sub is 1.093 cubic feet and gave the optimal box size as follows:
    13.95" wide
    21.46" high
    8.93" deep
    I'm using 18 mm thick MDF to build the box which is equivalent to 0.71 inches.
    What I'm wondering as I'm new to this is which size within this range would be best for a sealed enclosure. Pioneer gives a large range of sizes to use from 0.85 to 1.75 cubic feet and their recommendation is basically right in the middle of that range @ 1.25 cubic feet whereas WinISD gives an optimal of 1.093 cubic feet.
    What is the benefit of going as small as 0.85 cubic feet or as large as 1.75 cubic feet?
    I'm basically looking for 50-50 SQ/SPL and I realize going sealed vs ported is giving up some SPL hopefully in favor of some SQ... and that's fine with me for this first build. What I'd like to know though is how the size of the enclosure within that range from .85 cubic feet to 1.75 cubic feet effects the SQ and SPL.
    What size would you all recommend? What would sound the best and make optimal use of the sub for SQ/SPL in a sealed enclosure? Any advice is appreciated. Thanks in advance.
  2. Ranger SVO
    Small boxes tend to be peaky, great for rap but not for anything else. For me 1.25cu ft would be a good size, but I would go even larger. While I don't think most people could hear the difference between 1.25 and 1.5, I would still build the 1.5 cu ft box.
  3. MitaG3
    MitaG3 Full Member
    i'd take rangers advice. he's crazy smart with this stuff lol
