Im Installing An Aftermarket Stereo In A 2002 Chevy Tahoe With Onstar But Without The Bose Stereo Do Anyone Know If This Is Equipped With A Factory Amp And If So Where Is It Located And What Specific Bypasses Do I Need To Install The After Market Equipment I Am Doing A Complete Stereo Adding After Market Speaker And Head Unit With Amplifiers Any Info Would Be Helpful
If you wanna retain the OnStar you will need a PAC OS-1. This will allow the use of an aftermarket radio with your OnStar. You can also add amps if you want. If at all possible choose an aftermarket radio with a mute wire. The interface will work with radios with or without the mute wire, but it works better with.
