HELP!!?? Azn, Pedro
Discussion in 'Car Subwoofers' started by cccullen, Feb 19, 2008.
  1. cccullen
    need your help. The people i bought the amps from are telling me that they had already shipped the amps. In a nutshell i'm kinda screwed now. I do see an alternative though for the sub. Instead of getting one 15" L5 the seller i bought the sub from also is selling 2 10" L5's 4ohms DVC. Should i just go ahead and go with 2 10" L5's instead?
    I really don't have much of a choice now but what kind of difference are we talking about as far as box specs. how many cu. ft.? Also, RMS wattage of 2 L5's 10" is about 900 watts... 880 watts is enough to power these things. right?
  2. G3n3R@1
    G3n3R@1 Full Member
    i hope you didn't pay for em yet or at least they'll give the money back
  3. cccullen
    paid for everything already. That's what sucks.
  4. aznboi3644
    Well two 10's have significantly less cone area than a single 15.
    If you were going to use the 15 you could always use one coil...power handling would be reduced 20%
  5. cccullen
    Damn, i was thinking that too. I just got an email from the people i bought the amp from hopefully they will cancel it. I showed them 5 emails i sent them telling them not to ship the amps til the 26th. If they don't cancel the order then I may not have a choice then to go with the 2 10's.
    Would that be a good idea to only use one coil for the 15"?
  6. aznboi3644
    I've done it...works fine. Just don't put to much power to em.
    To 10s in a nice box should get pretty loud though
  7. cccullen
    Globazar just emailed me and it seemed like the are willing to cancel my order (i hope) if that does happen then I'm just going with HiFonics and put 900watts @ 2ohms to that L5 15". That should make it pound!
  8. cccullen
    Whew!!! Globazar canceled my order of the soundstream amps. So now I'm going to just buy Hifonics i guess unless you all have any better suggestions.. So i can still use the 15" L5. Problem solved!!!
  9. electrolytic
    electrolytic Full Member
    Which one did you get 06?
    Kicker builds the Solo-Baric L5 subs for powerhouse bass. The 06S15L54 15" subwoofer
    15" subwoofer with dual 4-ohm voice coils
    SoloKon aluminum-treated composite cone with Santoprene surround
    rigid steel basket
    power range: 50-750 RMS watts (375 watts per voice coil)
    peak power: 1500 watts
    frequency response: 18-100 Hz
    sensitivity: 90 dB
    mounting depth: 8-7/16"
    sealed box volume: 1.50-6.00 cubic feet
    ported box volume: 3.00-6.00 cu. ft.
    Recommended Q-Logic Box Type: 1, 2
  10. cccullen
    here's the one that I bought, it doesn't say the year model but it is brand new.
    KICKER S15L5 15" 1500 WATT SUBWOOFER SUB 4 OHM L5 NEW!! - eBay (item 280198871043 end time Feb-13-08 14:11:32 PST)
  11. cccullen
    Someone is offering me a PPI 5440 5 channel amp for 100 bucks shipped. I was thinking of using it for my wife's CRV to power her stock speakers along with the xplode sub. Do you think its a good buy?
    Specs:
    4 x 30W + 1 x 120W @ 4 ohms
    4 x 60W + 1 x 200W @ 2 ohms
    3 x 120W @ 4 ohms bridge
    The guy who was the highest bidder backed out and they are offering it to me.
    Here's the link:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260211381790&ru=http%3A%2F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26_trksid%3Dm37%26satitle%3D260211381790%26category0%3D%26fvi%3D1
