Help Alphasonik Vs ElevationAudio ?
Discussion in 'Car Stereo Amplifiers' started by water, Sep 18, 2009.
  1. water
    water New Member
    Ok here its my question I have an alphasonik PMA300CA 2-Channel High current Amplifier and i want to know if the ElevationAudio DX300.4 4-Channel Amp its better than the one i have now?
    Here are the Spect on the ElevationAudio
    Alphasonik Spect look like this
    Features:
    * 150 watts x 2 @4ohm
    * 270watts x 2 @2ohm
    * 450 watts x 2 @1ohm
    * 475watts x 1 @4ohm
    * 780 watts x 1 @2ohm
    * 900 watts x 1 @1ohm
    * Bridgeable
    * Hour Meter
    * Remote Mount PMA100V Digital Volt Meter
    * Remote Mount PMA10B Bass Boost Control
    * Heavy Duty One-Piece Extruded Aluminum Heat Sink
    * Beveled Clear Acrylic Protective Cover
    * Tiffany-Style RCA Jacks
    * Parallel Line-Out RCA Jacks
    * Removable Aluminum Side Covers Conceal Control & Terminal Panels
    * MOSFET High-Speed Switching Power Supply
    * Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating
    * Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages
    * Solid Brass Nickel-Plated Terminal Blocks (PMA800 & 1000HCA
    2-Gauge Power, 8-Gauge Speaker) (PMA150, 300, 600 & 640HCA
    4-Gauge Power, 8-Gauge Speaker)
    * Variable Low-Pass Filter: 50Hz~250Hz, 24dB/Octave
    * Variable High-Pass Filter: 50Hz~250Hz, 24dB/Octave
    * Variable Subsonic Filter: 20Hz~60Hz, 24dB/Octave
    * Variable Bass Boost @ 45Hz: 0 ~ +18dB
    * Variable Phase Shift: 0~180¾
    * THD: < 0.05%
    * Signal-to-Noise Ratio: >100dB
    * Frequency Response: 5Hz~50kHz
    * Input Impedance: 10k©
    * Input Sensitivity: 200mV~8V
    * 4-Way Protection Circuitry: Thermal, Short Circuit,
    Overload & DC Offset
    * Cooling Fan(s)
    * Dimensions (W x H x U 91/16 x 2 5/8 x 16 1/6
    Im a newbie when it come to this. But i read some where that the ElevationAudio its preaty clean and clear audio. if anybody can commend on this please
    1st. welcome.
    next question. what will the amp be powering?
  3. water
    water New Member
    Thank you. Great forum. :cool:
    Sorry forgot to mention. yeah its going to power 4 LC6 from Elevation audio
    I replace my factory speaker for 4 of this LC6 also added 4 tweeters
    Im nah sure if the tweeters are getting power from the amp. I had some one doing it for me
  4. pedro quiroga
    do you want the ability to fade front to back?
    BTW those tweeters are crap. i hope you dint pay much for them. sorry, ive heard them and blahhh comes to mind.
  5. water
    water New Member
    when you said fade front to back. you mean like when the blue tooth come to use the back sound shout down? my car came with surround sound two twtter in the front panel and two small speaker on the back ceiling and the bass speaker on the back. I had changed the four speakers on the doors and the two tweeter on the front panel. also added two extra tweeters under the dashboard. about the tweeter sound hmm im new to this so i don't know if its a good sound or not. but yeah it want the system to be like when it came from factory just with more power. we had it connected just Mono just getting the sound feed from the back speakers and it was really loud and clear. now after switching it back to stereo the sound its not as loud and not as clear as before. does the front speaker feed has something to do with it?
