Help a NEWB
Discussion in 'Car Subwoofers' started by afcollege09, May 24, 2010.
  1. afcollege09
    afcollege09 New Member
    Got the headunit installed and it works great.
    Took me forever to install and they are not working! Need some help.
    I took some pics if that will help you guys. The amp turns on (one green light) but the subs do not.
    I have the remote wire and rca from my head unit to the amp. The power and ground to the amp. Then the speaker wire from the sub terminal to the amp (+ and -).
    EDIT: The RCA cables are now hooked up on the right
  2. fstrfvo
    fstrfvo Full Member
    Is there a sub level control on the HU? Is it turned up or on? Are the gains turned up on the amp?
