Head unit questions
Discussion in 'Car Audio Head Units' started by Korporat Avengr, Mar 17, 2011.
  1. Korporat Avengr
    Korporat Avengr Full Member
    1. When you put amps in your car with the RCAs hooked up to the deck, do you have to disconnect the wires in the deck's wiring harness that went to the stock speakers?
    2. What are some things you can do to keep a head unit more securely in place if it's a little loose in the dash?
    unless the amp isnt powering the speakers then, no.
