having issues with MBQuart RAA4200 amp and Basslink sub... ADVICE?!
Discussion in 'Car Stereo Amplifiers' started by Jgerards, Nov 17, 2010.
  1. Jgerards
    Jgerards New Member
    Hey everyone,
    I'm having some issues getting decent level out of my sub.
    SETUP:
    Pioneer Head Unit
    (2) Infinity Kappa coaxial speakers
    (2) MBQuart Reference coaxial speakers
    MBQuart RAA4200 4-ch Amp
    Infinity Basslink Subwoofer w/ built-in amp
    Head unit itself is powering the woofers of each of the 4 speakers. Also it has two pairs of line outputs that are running to the amp which is powering the 4 tweeters. The amp also has a line level output which is running to the Basslink.
    PROBLEM:
    the sub is at a decent level only when the fade setting on the head unit is on full front or full back. the closer you get to balanced the less you get from the sub. When the fade setting is equal front/back, the subwoofer is too low to really be useable and I like the equal fade balance in the mids/tweets so I don't want to fade it all the way one direction just to be able to use the sub.
    I feel like there is something easy that I'm just missing. There is a 2/4-ch mode on the amp, but toggling that made no difference.
    Any feedback is appreciated. Thanks!
    Jeff
  2. Klinkster
    Klinkster Full Member
    How old is your HU? What model is it?
    I'm scratching my head to your wiring setup. It sounds like you are using line level outputs to all your speakers and not using any preouts(RCA). Am I correct?
    Why are you amping your tweeters and not your woofers? If they are coaxials, the tweets would be wired to the woofer from the factory. If the tweters are seperate, then they aren't coaxials, they are component speakers and that case you would wire them to a crossover instead.
    If you tapped your Sub amp to your speaker wires, which channel did you tap into? The rear?
    If you only have line level outputs(no RCA out) on your headunit, the way I'd wire this would be to have your 4ch amp hooked up to your rear channel. Wire up all four of your coaxials to the amp. The tweeters should be tapped into the woofer input if they aren't already wired that way. Then use the front channel speaker wires to supply signal to your sub amp.
    If you MUST have a fader, then wire up your front speakers to your HU's front speaker output and switch your amp to 2 channel mode and drive the rear speakers with the amp. Then tap your sub amp to one of your rear channels speaker wires (from HU not the amp)
  3. Jgerards
    Jgerards New Member
    I'm not sure the age of the head unit but it is older, probably 2006/7.
    and I apologize. You are right. They are component speakers, not coaxial. Got the terms confused. Each speaker came with a separate crossover. So in my setup, the crossovers were removed from the signal chain since the woofers and tweeters are run separately. I did it this way so I could run the tweeters through a higher quality amp than the head unit. I thought it would be more valuable to use the higher fidelity amp on the high end. And frankly, outside of the sub issue, I think it makes a pretty noticeable difference to my ears. I really like being able to control the high end with the amp's gain instead of the EQ settings on the head unit.
    So here is the wiring setup:
    HEAD UNIT - Front & Rear speaker level outputs go to mid-woofers in component speakers and (2) sets of RCAs go to the 4-ch amp.
    AMP - 4 outputs go to tweeters in component speakers and line level RCA output (thru?) goes to the RCA inputs on the Basslink which has both RCA and speaker level inputs.
    Hopefully that covers everything. Would it work just to parallel the front and back tweeters on each side to a single channel on the amp so I free up two channels and then use those to run to the sub? Or do that same thing, but instead of running the speaker level outs from the amp, I could run the 2nd set of RCAs from the head unit straight to the amp?
  4. connerray2010
    connerray2010 Full Member
    Not tring to steal this thread but hence where already on the quart topic. Are there 2way speakers any good. FKA116 and FSA216. Found a place with a pair of each and x overs for 100 with 1 year warranty. Sould I get them?
