I have someone local that might build me a bracket, but IDK if single or dual...depends on what needs to be done for pulleys? Can I just have a dual bracket with no pulleys, or how do I figure what I need? Thanks!
Not sure exactly what you mean? bracket with no pulleys? Are you referring to the alternator itself or the mounting bracket? cause i am unaware of a bracket that has ANY type of pulley...
I guess if adding multiple alts u need pulleys so the belt wraps partially around the pulley to avoid slip http://forum.ecoustics.com/bbs/messages/4/643429.html https://www.dcpowerinc.com/dual-alternator-kits.html?dir=asc&order=lester_number
Ok..... So you want to run 2 alternators ..... Well...at least run a double V belt. Better yet, run a serpintine. A serpintine will pull more horsepower with less slippage then a v belt. and do it with less loss. It takes approximatly 5-7 HP to crank out 60 amps of current. And a single v belt is good for about 50 amps at about 40% pulley engagement.....you do the math..... hope that helps you out.
ill be running 3 alts, 1 HO in stock location now and pulling AC to add 2 more off my serpentine yep, after I heard my van bog down on a load test, wow...better add a pulley!
